If you go to the dealership nowadays, you will probably get "right-side up" monotube replacement shocks instead of the "inverted" monotubes that came stock on our cars. Just check the boxes that the parts counter gives you before you accept delivery... if the dust tube is corrugated then it is the inverted type. If the dust tube is straight then it is the right-side-up design that will be more robust than the inverted. The valving and shock performance is the same as it was in '03-04.
Trilogy 58, owned since '08
