This is a 2004 black cobra with 3500 miles, yes that is right 3500 miles never wrecked or damaged.
The car was being built as a Silver State car, but the car never was finished. The guy has had it at a local shop for 2.5 years, but has done little with it for the past 9months. Due to the economic times, my very good friend, who owns it, wants nothing to do with the car any longer and asked me to just part it out. I have title in hand for this car. I will not sell it complete. It will be broke up in parts and sold off. I have itemized everything. Everything in this car is NEW and never ran. I have the CLEAR title in hand.
I want to keep a rolling chassis, so no individual body part will be sold. I do have options for the rear suspension and can offer a stock IRS, a built MACH1 solid rear and a stock 96-98 rear. Front suspension will be returned to stock configuration with options of your choice.
$11,000 as a chassis.
yes.....that's a REAL CobraR in the background!
HRE Wheels w/tires
T.ires are KDWs Rear tires are 295X35X18 and the fronts are 265X35X18
$4500.00
New G-Force T-56
It has never been ran.
$5200.00
The clutch is a twin disk 26 spline clutch and flywheel assy.. It is a one off set up, built by a Nascar shop in Vegas $850.00
DFI stand alone new in the box with latest Version.
$2000
5.1 Billet Stroker Engine
Oliver rods , custom CP pistons, custom crank, ARP2000 studs, Comedic head gaskets, Ported heads , 1mm over sized valves, custom Comp billet cams, Canton oil pan, billet oil pump, all new. This motor is ready to go. Custom black valve covers and black timing cover.
This is a totally one off built engine!
$13,500 for engine. Complete and ready to run!
Stop Tech brakes 355mm
Complete kit, lines, rotors and calipers The rotors are 2 piece. The calipers are black in color
$1800.00
Twin Turbo kit
This is a full custom twin turbo with 67mm Turbonetics ball bearing turbos. Tial waist gates, Maridyne cooling fans, PSR K member, MM coil overs, complete 3 in. stainless exhaust all the way to the rear axle, Sullivan intake, Sullivan fuel rails with Custom sheet metal intake, all new
$11000.00
