Results 1 to 3 of 3
Thread: TPS at 91% at WOT Good or Bad ???
    Jun 2002
    Pleasant Hill Ca. - across the bay from San Francisco.
    Question TPS at 91% at WOT Good or Bad ???
    Testing out new tool for OBD-II port. (Dennis can get them)
    One of the many sensor tests it does is cking. while driving is the TPS.
    At WOT my TPS only shows 91% open ---- should I not adjust to to 100%
    ie. 5volts ??? to get the most HP & TQ out of it at WOT ???
    At the stop sign it shows 17% to 19% ???
    Any Thoughts ???
    WarrenB
    TripleTransAm Guest
    From what I understand, the new Ford TPS does not emit a fixed voltage but some sort of a signal that represents the percentage of total signal range. I too get the similar (if not slightly higher - 21%?) reading at idle, but I can't remember the WOT value. Supposedly, the PCM considers anything past a certain % to be WOT, so you need to visually verify that a full pedal depression does translate to full-open-throttle.
    This new TPS is supposed to be much more reliable than the old fixed voltage TPS, according to what I heard (although I don't know how one can f*** up the old style, it's just a simple resistive wiper).
    Houston
    TPS readings are normal. Your cars computer (EEC-V) reads 0-5volts returned through the TPS. Once inside the computer it's converted to a number in the form of Analog-To-Digital counts, say 0-4095.
    When you use a OBD-II data logger to see the TPS, they usually automatically read the counts and then peform a conversion to give you volts or % of max volts.
    The computer monitors the TPS for minimum voltage and uses this for its closed throttle reading. It starts using a new reading every time the power is cycled. Now as far as WOT, there's a preset value in addition to minimum measured. And WOT mode in the computer actually happens at a point lower than full open of the throttle blade.
    It is not necessary or desired to have closed throttle = 0 volts and WOT = 5 volts.
    2002 White F250 7.3 - Turbo
  1. Replies: 15
    Last Post: 08-25-2004, 01:16 PM
  2. 300C, The Good, The Bad, and The Ugly
    By SouLRioT in forum Community Discussion
    Last Post: 06-03-2004, 07:39 AM
  3. The good, the bad and the ugly
    By spotbearsd in forum Community Discussion
    Last Post: 02-18-2004, 08:02 PM
