If the car kept going up until max height, suspect the height sensor. It is located directly above the rear axle to the left (driver's side) of center. The switch is attached to the frame and has an arm that runs down to the left side Watts link arm. Both ends of the linkage have ball end connectors. Usually they don't fall off unless something hits them, but they have been known to break, especially it seems when "crabbing" over a steep driveway. The switch senses too high or too low by the movement of the linkage. The lower end attached to the Watts link is adjustable by loosening 2 (different size) small bolts. Then move the end side to side until proper height is set.
If the linkage is broken, it will be visable.
1 of 111 Without Heated Seats
6 CD Changer in Trunk
Locking Lugs
Trunk Organizer
Marauder Side Emblems
Rear Bumper Inserts
Nephews: Blue w/Light Flint
Born 02/05/03
2011 of 7838.
Locking Lugs
Trunk Organizer
Factory Alarm
Rear Bumper Inserts
6705 of 7838 2003's
Built Friday 02-07-2003
Bought 09-10-2012
#5 2003 DBP/Light Flint
6741 of 7838 2003's
Built Tuesday 02-11-2003
Bought 05-06-14
