Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Mounting JRI coilovers
    Jan 2006
    Northern California
    The JRI coilovers and separate smartphone JRide unit require a custom mount made. So, KC of BRG Racing used one of his favorite toys: a portable coordinate measuring machine (CMM).
    The tech measures the mounting holes and distances around the area to create on the CAD program a cylinder mount, which is used with a CnC KC owns to cut out of a solid block of 7075 aluminum. I will share the picture of the mounting scheme later.
    Nov 2007
    San Jose
    I'm still confused why the factory mounts aren't adequate. I guess I'll see soon enough. I see a spherical rod end on the upper, presuming that is the front shock on the table. Factory is just a threaded shaft.
    Lifespeed
    Jan 2006
    Northern California
    The stock mount will not work with most aftermarket performance shocks. Thus, a custom mount must be made. On the table is a the shock with the JRide controller in red tied together with bi-directional hi psi hoses.
    stock front mount works fine for coilovers, My ridetech's fit and ride fine and have adjustment capabilities. stock rear mounts not designed for load bearing.
    Nov 2007
    San Jose
    Quote Originally Posted by Lowndex View Post
    I thought JRI was going to match the stock shaft threads in order to retain stock travel.
    Lifespeed
    Jan 2006
    Northern California
    Agreed and Ridetech are good coilovers. Coilovers such as those below are not designed for Mercury Marauders and will need customer mounting.
    Bilstein PSS9
    Koni
    HKS Hipermax Max4GT
    KM Variant 3
    H&R Club Sport
    D2
    KSSport GT Pro
    Tein Street Flex
    JRi
    The ridetechs come with a mount designed for panther chassis that mounts to stock shock tower. I don't need $8k shocks and $2k+ custom mounts.
    Jan 2006
    Northern California
    Glad you are happy with what you have. Now let me do the same.
    Oct 2010
    What an EPIC FAIL and total waste of money!
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Jan 2017
    Springfield Mo
    Cant wait to see the finished product. I hope you enjoy the new system.
    I really wish more companies would build aftermarket parts for these cars but it looks like aside from a few, we are alone to build our own stuff.
    Jan 2006
    Northern California
    Quote Originally Posted by Mackdombles View Post
    Thank you. They simply did not make enough Marauders for enough years to support the parts business. But, where there is a will, there is a way.
    Feb 2012
    harrison twp,mi
    Your car your money.
    Be happy, you will have one of one.
    People say but why, because why not.
    Enjoy doing your car your way.
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    Feb 2012
    harrison twp,mi
    Oh, and now a portable cmm is on my wish list.
    Very very cool.
    Smile and Nod
    I love THIS bar
    Quote Originally Posted by lji372 View Post
    I agree.....Over the top build!!
    ...but I do want to know the total outlay when your Marauder is complete!
    (I bet you could have bought a FORD GT instead)
    Blog Entries
    2
    06-30-2005, 03:22 PM
    pacammer's Avatar
    pacammer pacammer is offline
    Pacammer
    Trader: (0)
    Post Feedback
    Can a Marauder hold its own on the track with a Lamborgini?
    To make a short story long I own an 04 DTR Marauder. It has had all the Dennis, Zack/Mac majic done to it. In the past 2 years it has won 3rd then 2nd place in the All Ford Nationals at Carlisle, PA.
    I am a member of the Eastern Pantera Club. We co sponsor a track event at Pocono International Raceway yearly with various other Italian Car Clubs such as Lamborgini, Maserati, and Ferrari. Since my Pantera is in pieces I asked and was permitted to bring the Marauder to the track to run. As I stated in a post a while back I am not a drag racer. I use my car every day and in the snow so I opted for a centrifigul vs. roots type supercharger. I have not changed my rear end ratio. I do however like to run in track events.
    Well I lined up to run with 19 other cars, all newer model Italian high performance exotic cars. We run NASCAR wise, counter clockwise. We used turn 1, turn 2, then an infield course that has a 270, three 90's, two 75 degree turns and a chicane, then we enter back onto the main staight with 2/3 of that straight available before turn 1.
    Well boys and girls I have to tell you after 5 laps everyone in attendance was looking at this Canadian maufactured, Dearborn Sedan. It ate cars like it was at an Italian buffet. Not only did the Marauder hold it's own on the banked turns it passed most and stayed with the best of them in the infield. Comming out of the infield onto the main straight I devoured them. The available touque was awsome. I ran with the antilock brakes and overdrive off. Down the straight going into turn one, 135 mph+ easy. 130 mph+ into turn 2 and an average speed through the infield of 60+ mph.
    The transmission mods worked great, that baby knew when to down shift upon hard braking. The supercharger spun up smoothly so the ass end never kicked out. Dennis's total package and the Zack/Mac control arms worked flawlessly.
    After I came off the track nearly everone came over to see the car. Most of these folks told me they thought it was a joke putting the DTR on the track against these 6 figure cars. On day two I repeated the same results. No fluke.
    A lot of exotic car owners have a new found respect for our "Family Sedans / Cop Cars". Needless to say I had a blast.
    Sorry for the long story but I just had to brag a little. Enjoy your Marauders they are all special.
  1. Ridetech Coilovers
    By Black&Gifted in forum Steering, Suspension & Brakes
    Last Post: 07-04-2017, 09:21 AM
  2. Naake Front Coilovers
    By FordNut in forum Steering, Suspension & Brakes
    Last Post: 09-02-2016, 07:37 PM
  3. installing front Naake coilovers
    By burt ragio in forum Steering, Suspension & Brakes
    Last Post: 06-03-2008, 04:23 AM
  4. Naake Coilovers and Shocks
    By Zack in forum Other Parts for Sale
    Last Post: 12-11-2007, 09:46 AM
  5. Scangauge Mounting
    By MarauderBoy in forum Linear Logic
    Last Post: 10-08-2007, 05:18 PM
