Results 1 to 14 of 14
Thread: Rack and pinion
    Dec 2015
    Blytheville, Ar
    Rack and pinion
    Does anybody know if marauders have a different rack and pinion than a regular marquis? Had to have mine replaced, and it now feels twice as easy and just feels weird now, like I can feel more bumps from the road thru the wheel... I checked in AutoZone, it shows they have the same part number. .
    Quote Originally Posted by dustybo83 View Post
    Your replacement probably doesn't have the variable assist.
    Dec 2015
    Blytheville, Ar
    How would I go about checking that? I had the work done for me at a local shop. Are there certain years of panther bodies that have them or is that marauder specific?
    Look on the drivers side of the rack. There should be a valve with an electrical connection.
    Dec 2015
    Blytheville, Ar
    Okay, thanks!
    Lehigh Valley, PA
    The original rack part numbers were different between a Marauder and CV/GM. Sadly I do not have them in front of me but this topic came up in an argument years ago with friends and I went around looking for evidence.
    I think any PN you find on a dealer site today will be a reman PN which will cross to all panthers.
    Edit, this isn't the original PN but it's as close as I'll find in 30 seconds on google.
    3W1Z-3504-GARM
    This one is a reman PN from motorcraft that says 03/04 Marauder only, as seen here on Tasca.
    https://www.tascaparts.com/oem-parts...r-3w1z3504garm
    I always thought the VAPS on the Marauder rack was tuned to provide heavier steering compared to a CV/GM which would explain the reason for a different part number (and why your steering feels super light now). Not 100% sure if that is correct though. You could try swapping the VAPS valve from your old rack onto the new one and see if it makes a change.
    2063/3214
    5377/7838
    Timbuk3, MI
    Lightbulb
    *.attachment
    NOTE: Excerpted from the parts list at - Documents: Mercury Marauder ««« -click-
    3W1Z-3504-GARM
    VAPS made the steering lighter at low speeds, heavier at higher speeds.
    Lehigh Valley, PA
    I remember being able to spin the steering wheel in my friends 06 vic at parking lot speeds with one finger, I would wager the VAPS is different enough to affect the overall assist ratio.
    2063/3214
    5377/7838
    Dec 2017
    Tulsa, OK
    Ratios and lock to lock appear to be different between the MM and MGM but the MM and CV appear to be the same but I am getting this info from different Google searches thus different sources:
    MM - 2.28 lock to lock and 18.5 ratio
    MGM - 3.4 lock to lock and 16.4 ratio
    CV - 2.92 lock to lock and 18.5 ratio (P71's appear to be the same)
    I am pretty sure that this information is in alignment and frame manuals so if you can find a Ford body shop willing to let you dig through theirs that would be 100% accurate.
    Lehigh Valley, PA
    Quote Originally Posted by Aerocoupe View Post
    16.4 is the ratio for the old steering gear cars
    2063/3214
    5377/7838
    Dec 2014
    Hastings, mi
    Was running various year/model configurations through nspa, every thing I looked up showed with or w/o Evo. But all racks had evo just whether or not it came with the valve itself. Was there any usable rack that fits the marauder that doesn't use the valve at all?
    #BSTDMRC #LSSWAPPEDMARAUDER
    Instagram -
    Cheapthrillb2
    lsswappedmarauder
    Sep 2005
    APPLE VALLEY,CA
    They are definitely different.
    The wiring is different and shouldn’t match up.
    I had to purchase a remanufactured unit from Florida.
    Jul 2014
    Castine, Maine & Brooklyn, NY & Walton, NY
    Who can rebuild the original?
  1. Wanted To Buy rack and pinion
    By BLACKMARAUDER04 in forum Marauder Parts/Misc. Wanted
    Last Post: 05-16-2018, 02:14 PM
  2. Replace rack & pinion?
    By F1erceK in forum Shop Talk
    Last Post: 03-17-2016, 07:04 AM
  3. Do I need a new Rack and Pinion ??
    By MADRODER in forum Shop Talk
    Last Post: 05-09-2015, 01:45 PM
  4. rack and pinion
    By jvillerauder in forum Shop Talk
    Last Post: 04-13-2009, 01:54 PM
  5. Rack & Pinion DOA
    By N40GL in forum Shop Talk
    Last Post: 02-15-2008, 07:44 PM
