Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: New Ignition Coils
    Apr 2007
    Fort Lauderdale,Fl
    New Ignition Coils
    Well, im at 96K miles... and starting to think about how my engine is doing... and realized that i have never changed the engine coils...
    what is the intervals of this change? and is it indeed necessary to do so?
    i went to rockauto.com, and its a tad confusing... is cyinder 1,2 different coils from the rest? because rockauto sure does position it that way..
    if anyone else has any tuneup tips, let me know.
    Nov 2009
    Fort myers
    If there not giving you any problems I would say your good. Some here have reported stock coils well over 100,000 miles, 1&2 are different and most of the guys here simply reccomend granatelli steel connectors in exchange of the stock coil wire spring. I have had coil problems and believe me its something you can feel!
    Quote Originally Posted by Ktorres1 View Post
    +1.
    Only need to change them if there is a problem.
    Highly recommend the Granatelli coil connectors.
    Ft. Lauderdale, Florida
    change all 8
    I had running and idle problems caused by numerous bad coils
    I put in a set of 8 ACCEL coils purchased from summit
    Part number 140034-8
    this made a huge difference, smooth idle..more power...etc
    I did my coils at 80K
    Sold on 1/16/2012
    MM 2003 300A
    Reinhart Air-to-Air Vortech Supercharger #8, Art Carr Transmission, PI 3000 stall TC Triple disc, 4:10, TA Girdle and studs, Dynotech Driveshaft
    DR Xcal2 tune, Motorcraft AGSF22C Plugs(Autolite 103) Trying some NGK Iridium, New ACCEL COP's, Rear engine cooling mod
    180 deg. Thermostat, KOOKs headers, Magnaflow high flow cats (NO CATS), Magnaflow Mufflers (with stuffing blown out)
    Addco front & rear sway bars, Metco drive shaft loop, Metco control arms, ProGuard Skid plate
    Widened rims by Weldcraft w/Nitto 235/45 & 285/50, DynoPros Aluminium Door Sills
    http://www.mercurymarauder.net/forum...do=view&id=474
    Quote Originally Posted by Midnight View Post
    Never heard of such a thing.
    Oct 2003
    Beaufort, SC
    213,3xx miles on my OEM's with Granatelli connectors and not a single hic-up!!!
    Jun 2004
    Are you talking the wires or coil packs? I too have the Granatelli's and like them, but they are the wires, not the coil packs.
    The Dirty South
    If your not throwing a CEL then the coils are fine. If your swapping them just to do something you may be surprised just how good the stock coils are. If you want to just improve the coil set up get some LFP coil connectors, they are alot cheaper than the GMS and are the same quality.
    Oct 2003
    Beaufort, SC
    Just the connectors that replace the "Springy Thingies" Ford put in!!
    Jun 2004
    Yep, no comparison between the OEM ballpoint pen springs and the aftermarkets.
    Apr 2005
    Queens NY
    +1 I been running the LFP coil connectors for a while, they are $50 cheaper then the GMS and look and perform identical.
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    not quite right
    My Car was just running very wierd, surging idle...not alot of power.......
    and there was NO CEL light.....that would have taken forever to show a CEL light....maybe a dead coil will show a CEL but intermittent does not
    Sold on 1/16/2012
    MM 2003 300A
    The Dirty South
    I've seen bad coils with an intermittent pulse throw a CEL as a mis-fire on the cylinder good Sir. All cases are diffrent so it does'nt mean i'm right or your wrong.
    There is a threshold of misfires that needs to occur before a CEL will come on. Also, keep in mind, that at idle the coils fire 3 times, as opposed to running at speed, when they only fire 1 time.
    Trilogy # 192 / T.S. 0012
    Apr 2007
    Fort Lauderdale,Fl
    Well, im feeling a lack of power recently... i lay down the accelerator, and it doesn't matter where i put my foot... the car just doesn't move... the car does have a sweet spot... where theirs not too much air, not too much fuel, and you ride the pedal into that..... but thats slow coming...
    i have changed my spark plugs before, and two coils have gone bad.. 6,7 if not mistaken.
    but, if someone knew of a good upgrade, fairly inexpensive. id pursue it...
    also, maybe i could use a tune too.
  1. So you don't like cut coils, is it because....
    By justbob in forum Steering, Suspension & Brakes
    Last Post: 12-07-2009, 06:24 PM
  2. Replies: 13
    Last Post: 11-02-2009, 01:16 PM
  3. I need 2 ignition coils
    By james1986fox in forum Marauder Parts/Misc. Wanted
    Last Post: 03-25-2009, 02:56 AM
  4. new and used coils
    By safado in forum Marauder-specific Parts for Sale
    Last Post: 02-06-2008, 10:13 PM
  5. plasma direct ignition coils
    By nexstar7 in forum Shop Talk
    Last Post: 10-26-2004, 05:17 PM
