I consider mine close to OEM stock........
CAI, gears and a tune is lightly modded....
I'd say once you pull the engine for a forged rebuild, you are heavily modded.
Or if you have a S/C, aftermarket exhaust, gears, T/C....etc.
Almost all of the mods we do to our MMs are 'bolt-ons' but once you have replaced major OEM parts you are heavily modded.
