MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 05-18-2017, 02:34 AM
RowdyRauder RowdyRauder is offline
Member
Trader: (0)
No oil pressure, no power, and cuts off.
My 04' MM. Died on me yesterday. It has felt sluggish on wot for awhile. While passing a car yesterday it down shifted fine . RPMs were rising but, she wasn't moving much. Engine noise rattle. No warning lights. Noticed the oil pressure gauge at zero. Car quickly lost power and shut off. It was low 1.5 quarts. Added oil. No dice. Towed home. Hours later it starts. Oil pressure is normal then soon falls. Give it gas, no power , oil pressure drops again, bogs and dies. I love this car. Bought it used about 5 years ago. It only has 167,000 miles on it . Read through some of the oil pressure threads but, only found one with a similar story. But, don't know how it was resolved.
  #2
Old 05-18-2017, 02:46 AM
Gryphonzus's Avatar
Gryphonzus Gryphonzus is offline
Member
Trader: (2)
I think I remember reading that our oil pumps have weak gears. Might need a new one. Sorry no other ideas.
__________________
2004 SB Marauder, SOLD
2015 Blue Jean 4X4 F150 Platinum FX4
  #3
Old 05-18-2017, 05:00 AM
mm svt mm svt is offline
Senior Member
Trader: (0)
Drain it and try 5w40, why was it low on oil? Leak or burning it? What did your engine temp go to? There are others here that will have your answer but low, old, hot oil and you will have a very restrictive rotating assembly.
If you love it check the oil more often.
  #4
Old 05-18-2017, 07:05 AM
fastblackmerc's Avatar
Trader: (75)
My thought is the oil pump +.
__________________
  #5
Old 05-18-2017, 10:17 AM
Member
Trader: (0)
Temperature was good. The leak was at the oil sending. Switch . Front driver side . Can a bad oil pump cause this? Is it a safety feature to shut down like that? Thanks for your time guys.
  #6
Old 05-18-2017, 01:02 PM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
The oil pressure switch is only connected to the gauge...nothing else in the car knows what the actual pressure is.
Yours is a slightly unusual problem in that once the pump fails, it usually doesn't "recover" the way you've described. Fortunately, replacing the pump is relatively easy and doesn't require removal of the oil pan.
__________________
The Velvet Fog
2000 Grand Marquis GS
No name yet
Work In Progress
  #7
Old 05-18-2017, 01:30 PM
Spectragod's Avatar
Spectragod Spectragod is offline
Willing to meet up half way
Trader: (45)
Really???????
But you do have to remove the timing chains, tensioners, guides, timing gear off the crank, all the accessories off the front, the timing cover, but you don't have to drop the pan.....
So it's easy, lol.
__________________
Trilogy # 192 / T.S. 0012
  #8
Old 05-18-2017, 05:07 PM
Trader: (2)
That's why I said "relatively". If the oil pump is bad then it would probably be a good idea to at least do the tensioners and guides while it's apart and removing the oil pump at that point isn't a lot of extra work.
__________________
The Velvet Fog
No name yet
Work In Progress
  #9
Old 05-18-2017, 05:48 PM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
I bet your dealing with at least two different issues.
Bad gauge/ bad sending unit
And quite possibly a fuel pump or driver for stalling.
__________________
  #10
Old 05-18-2017, 08:10 PM
Senior Member
Trader: (0)
Bob such a great thought.
That's a best case scenario hope it's easier like a fuse to the fpdm
  #11
Old 05-19-2017, 01:03 AM
DWSTANG67's Avatar
DWSTANG67 DWSTANG67 is offline
DRIVE IT LIKE YOU STOLE IT
Trader: (1)
The oil pressure SWITCH is only connected to the gauge...nothing else in the car knows what the actual pressure is.
Take noticed in this post that your oil pressure is a switch not a sensor when it has pressure it reads normal pressure when it has none like if your pump failed it will read zero at that point you are running with no oil pressure and no or little flow so your engine was about to seize. THE GAUGE AND SENSOR DOES NOT READ YOUR TRUE OIL PRESSURE, IT'S A SWITCH
__________________
DEAN
TRENTON NJ
03 300A MARAUDER
BLACK THE ONLY COLOR
BORN 6/24/02 VIN 617134 #1844
VIST MY GARAGE
  #12
Old 05-19-2017, 06:48 AM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (39)
The oil pan most definitely needs to be removed to change the oil pump.
  #13
Old 05-19-2017, 07:24 AM
Trader: (2)
Quote:
I thought since the pump was mounted to the front of the block it would just slide off the crank snout.
I stand corrected.
__________________
The Velvet Fog
No name yet
Work In Progress
  #14
Old 05-19-2017, 07:26 AM
Zack's Avatar
Turbo Marauder
Trader: (39)
I stand corrected.
The pickup tube bolts to it from the bottom.
It is 'possible' but it would be quite challenging
  #15
Senior Member
Trader: (0)
Thank you, my thoughts exactly but didn't want to stick neck out but I remember having to remove the pickup tube stand to remove the pump on the cv
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advice on replacing Power Steering High Pressure Hose dankwun Shop Talk 2 02-21-2015 10:01 AM
Power Steering Pressure sensor RF Overlord Shop Talk 9 08-11-2014 08:44 AM
Wanted To Buy power steering pressure switch 707marauder Marauder Parts/Misc. Wanted 5 03-03-2012 10:29 AM
Eatc cuts on by itself! frdwrnch Shop Talk 7 01-04-2012 05:19 PM
Motive 0107 FORD Pressure Brake & Clutch Power Bleeder - like new(NO RESERVE on eBay) Warpath Misc for Sale 2 04-26-2008 11:03 AM
Powered by: vBulletin
