Does anyone know what size max and btu max stack plate we can out in our OEM trans coolers? I was looking at B&M 11"x8"x1-1/2" 20,500 BTU
Plate - "EVILMERC"
Or replace the stock cooler with
http://www.bulkpart.com/Merchant2/me...roduct_Count=4
Darrin
Here's mine:
Picture thru the grill
Cooler lines hooked up
Cooler lines routed
Connected to the cooler
Top view
Hook it up in series with the stock cooler, so the fluid goes thru the stock cooler then the aux cooler.
No, got this at a FLAPS.
2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
Darrin,
I put a small "Frame Rail" cooler before my OEM and it dropped the temp from 200+ to around 180* to 190*......highway with ambient of 75*.....what is optimum??
Around town it barely reaches 180*!!
Marauderjack
PS: I still have the OEM separator plate you sent me if you know someone who wants it or you need it!!
Someone above mentioned that the cooler I pointed to was without the bypass.
That was a good observation. I linked that one on purpose because your cars have a thermal bypass installed from the factory already and you would never want to put another one inline with it.
If the thermal bypass fails then the transmission will overheat. Putting a 2nd one in play not only doubles your chances of that, but it also acts as a restriction to flow.
Darrin
I mounted one of these behind my front grille.
........................V V V.........................
http://www.bmracing.com/PRODUCTS/Hi-...Cooling-System
The fan will come on when I am in traffic and in the pits after a 1/4 mile run.
I mounted it in series with the OEM cooler.
I NEVER see my transmission temps go above 180 degrees anymore.
Exhaust by Greg
I have the same setup as fastblackmerc. Bought mine on ebay, got the extra hose and clamps from the flaps.
2003 300B
VIN: 677166, #6738 of 7839
built: 2/13/03
wrty start: 5/28/03
84,197 on 02/21/08
95,776 on 02/21/09
109,301 on 02/21/10
121,447 on 02/21/11
125,925 on 02/26/12
130,375 on 01/01/13
134,831 on 2/4/14
149,441 on 2/24/18
Dark Blue Pearl, #128 of 327
