Originally Posted by
NorthShoreChiMM
From what Ive seen online and in person everybody seems to go the supercharger/procharger route. Can decent power (4-500) be made from a NA MM? Can that be achieved With cams, stroker crank, ported heads, headers and larger tubing throughout the exhaust system, and any other myriad of mods. Thanks
Mike
NO....
Don't waste your time and money.
I dumped over $7,000 into a built 5.0 Big Bore with all the goodies.
Made 325 HP/340 TRQ at the wheels. (about 400 HP at the crank)
Ran 12.9s N/A.
Would I do it again? .....NO!!!
Get forced induction for the weak 4.6 or go straight to a (bullet proof) OEM Coyote 5.0.
Actually....now that the 2018 Coyote is making an (under-rated) 460 HP....I wouldn't waste a dime on modding a 4.6. (It was a neat engine.....15 years ago.)
