Originally Posted by
Ross
My understanding is that the volt gauge is "real." I know that mine reads around 14 volts, and has appropriate dips when you would expect it to (idling with lights and AC on, etc.). Has never dipped below about 12.5, which I think is about as low as it should go unless there is a problem.
Yes the Voltage gauge is real, but if you replace the Oil Pressure Gauge,
the faces of the two Gauges won't match up.
That's why some are replacing the Voltage Gauge.
Pete...
DOB 10/31/2003
DOP 1/2/2004
DOB 12/11/2018
DOP 6/19/2019
