MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > Marauder Community > The Classic Lounge
The Classic Lounge Home of the 63-65, 69-70 Classic Marauders
Reply
Thread Tools Display Modes
  #1
Old 02-07-2019, 10:46 AM
TexasMotorhead TexasMotorhead is offline
Junior Member
Trader: (0)
16 Years in a Mercury Marauder ..
We've had a lot of adventures, and no major failures - all routine maintenance. Gonna drive her 'till something goes "BANG!!!"...
Sent from my Pixel using Tapatalk
  #2
Old 02-07-2019, 11:13 AM
NXSBOB's Avatar
NXSBOB NXSBOB is offline
Member
Trader: (18)
Congratulations!
  #3
Old 02-07-2019, 11:21 AM
88LTDCV351's Avatar
88LTDCV351 88LTDCV351 is offline
Senior Member
Trader: (2)
Wow! And no valve seat repair during that time?
__________________
1988 LTD Crown Victoria S
  #4
Old 02-07-2019, 07:03 PM
Invective's Avatar
Invective Invective is offline
Supporting Member
Trader: (4)
Nice! Mods? Please tell us about the service issues you did have.
__________________
Current Garage:
2004 DTR Marauder
2005 Mustang GT Premium
2006 Ranger XLT Extended Cab 4 Door 4.0L 4WD
2008 Triumph Sprint ST
2015 Triumph Trophy SE
“Twenty years from now you will be more disappointed by the things that you didn’t do than by the ones you did do, so throw off the bowlines, sail away from safe harbor, catch the trade winds in your sails. Explore, Dream, Discover.” Mark Twain
  #5
Old 02-07-2019, 07:23 PM
Agent2006 Agent2006 is offline
Senior Member
Trader: (0)
Moar info!
What oil, what other PM's...what mods if any....I want my 131K to get to that mileage. After being on death row, mine got sprung on a technicality. Now how to rack up those miles ?....and adventures....
  #6
Old 02-07-2019, 10:47 PM
1Marauder's Avatar
Senior Member
Trader: (5)
FRICKEN AWESOME... AND GOOD FOR YOU! CONGRATS! Hope you hit 500,000!
__________________
  #7
Old 02-11-2019, 02:18 PM
Gerry24's Avatar
Gerry24 Gerry24 is offline
Senior Member
Trader: (1)
Nice
__________________
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15.
  #8
Old 02-19-2019, 08:34 AM
Junior Member
Trader: (0)
Quote:
Nope. Engine, transmission have never been opened. Though I have taken care of fluid and filter changes religiously ..
  #9
Old 02-19-2019, 08:39 AM
Junior Member
Trader: (0)
Quote:
It's all OEM. Even have a Motorcraft battery. Service issues have been few. Virtually all the rubber up front, control arms, shocks (KYBs were crap, good old Monroe's did the trick), oil filter housing leak, pinion seal leak. Rear wheel bearings and axles. I change oil filter every 5k miles, engine oil every 15k.
  #10
Old 02-19-2019, 08:45 AM
Senior Member
Trader: (0)
what type of oil ?15K I assume full synthetic. I'm surprised, when I change my oil at 6K its pretty dark.
  #11
Old 02-19-2019, 08:47 AM
Junior Member
Trader: (0)
Quote:
Originally Posted by Agent2006 View Post
Moar info!
I use O'Reiley full synthetic 5W-20, 'cause... if it meets the API spec, it meets the API spec. Stopped using Mobile 1 at 100k. I take very good care of the differential. I use any SAE 80-90, but I go to Ford for the additive. I've lost one set of axle bearings (and one axle ..), but I believe that was the result of a leaking pinion seal. Spend some quality time under the car, look for bad rubber up front and blown shocks. Oil leaks are rare and straightforward to fix. But guess what? The coolant hoses are hard to find...
  #12
Old 02-19-2019, 08:52 AM
Invective's Avatar
Supporting Member
Trader: (4)
Thumbs up Marauder
A testament to the car's inherent quality and caring owner. Just replaced my OEM rear shocks with Monroe OESpectrum shocks. Nothing fancy.
__________________
Current Garage:
2004 DTR Marauder
  #13
Junior Member
Trader: (0)
Also, forgot to mention I changed the tranny filter (need to drop the pan for that) at 200k miles. There are several magnets on the pan which had collected a lot of metal. I think those magnets are probably more important than the filter...
  #14
Old 02-19-2019, 09:14 AM
Junior Member
Trader: (0)
Since y'all are curious, I've attached my PM schedule which tells the story...Mercury_Marauder PMs.xls
  #15
Old 02-19-2019, 11:17 AM
Senior Member
Trader: (0)
this proves you CAN keep these cars running pretty much as long as you want them to. Unlike some others, my old Subaru XT coupe had shock tower sag issues/body integrity problem that was terminal. THANKS for sharing the PM spreadsheet
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
50 years of Mercury Marauders – The Official Launch of the Mercury Marauder kirk Community Discussion 7 02-14-2013 02:51 PM
50 years of Mercury Marauders – part 4 – Job 1 kirk Community Discussion 3 01-28-2013 01:19 PM
50 years of Mercury Marauders – part 3 kirk Community Discussion 2 01-17-2013 06:05 AM
50 years of Mercury Marauders – part 2 kirk Community Discussion 9 01-13-2013 01:40 PM
50 years of Mercury Marauders - part 1 kirk Community Discussion 1 01-08-2013 05:50 PM
Powered by: vBulletin
