MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Suspension & Brakes
Suspension & Brakes Post your discussions about suspension, shocks, control arms and brakes here!
Reply
Thread Tools Display Modes
  #1
Old 08-02-2017, 07:10 AM
poohc1979 poohc1979 is offline
Junior Member
Trader: (0)
Air bags
Do any body have rear strut bags for mm
  #2
Old 08-02-2017, 07:12 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
OEM avail thru tascaparts.com or aftermarket Arnott or Suncore
They are air springs, not struts
__________________
  #3
Old 08-02-2017, 02:39 PM
Svashtar's Avatar
Svashtar Svashtar is offline
Trying to get it right...
Trader: (0)
Air bags
Want to avoid a new thread on the same subject.
I did the research on the options based on this same info posted the other day; hate to spend the $ but think I'm going to stick with the OEM parts to fix my constantly refilling bags.
More important to me is to know why they failed now. Assume the bags get more stretched out if the back of the car is on stands? Don't want to stress them again.
Other than the car sitting for two weeks I can't think of another reason for them to start leaking right after this work. Maybe just old and
coincidence, but doubtful.
I think I found a GM how-to video on replacing these. Would it be the same for a MM and do I need a lift?
Thanks.
__________________
  #4
Old 08-02-2017, 03:16 PM
Weißbirke Plünderer
Trader: (11)
turn OFF rear suspension when jacking up rear of car...always
__________________
  #5
Old 08-02-2017, 03:33 PM
Gerry24's Avatar
Gerry24 Gerry24 is offline
Senior Member
Trader: (1)
Quote:
What^^^ said. Air suspension 101, crazy thing is most of the lube shops don't even know that
__________________
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15.
  #6
Old 08-02-2017, 04:14 PM
BAD MERC's Avatar
BAD MERC BAD MERC is offline
#2,187 out of 3,214
Trader: (3)
Mine drop within 5 minutes of parking. Why not? It's only been garaged since new and just turned 49K miles. Oh well I believe the Arnott ones are the ticket but the heavy duty limo version is what's required. Less than $300 with new bags and solenoids delivered! That's a steal.
__________________
'04 Silver Marauder w/ sunroof - HID lighting, JL Audio / Eclipse DVD/NAV/iPod/camera, 4.10's, 2" drop, Progard, Delete tips, Billet Pedals, BC4E dead pedal, Lidio Tune, Innovative chin spoiler, K&N CAI, TCE SS lines, Super40's, tinted tails, SS Inserts, Heinous Control Arms, Real oil gauge, Steeda UDP.
2004 Mercury Marauder
#2,187 of 3,214
997 in Silver Birch
448 with light flint interior
304 with heated seats
336 with sunroof
  #7
Old 08-02-2017, 07:13 PM
Svashtar's Avatar
Trader: (0)
I know, I know. $h@(, my bad. I really thought the only reason to turn off the switch in most cases was to prevent the compressor from kicking in so it didn't shift the car while someone was under it.
When I backed it up on ramps I turned it off, and when up on both jackstands later it was off, but I had each rear by itself up, one for several hours while I fought a stuck rotor.
I swear I never heard it try to fill, but something got buggered. Drives fine, but compressor kicks in every 7-8 minutes.
114k, had to do them eventually, but I try not to help things along.
__________________
  #8
Old 08-02-2017, 07:20 PM
Svashtar's Avatar
Trader: (0)
Air bags
Quote:
Man, you got boned there if they're failing at 49K. Has to be age obviously not miles.
Is that what you're going with, the Arnott's? I want to check out the other ones RCR mentioned as well. Suncore IIRC.
Are you sure the HD limo ones are needed, and the standard ones won't work? Let me look into those; that's half the OEM. Good or bad I'd like to keep the air instead of steel springs.
Now, if someone can please give me an idea on the install? And I'll go away for a while (at least for a day...)
Please disregard; I see Arnott has install instructions. I'll figure it out, thanks!
__________________
  #9
Old 08-03-2017, 06:11 AM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
Quote:
That is actually the correct reason. Leaving the switch on while jacking won't damage anything by itself.
__________________
The Velvet Fog
2000 Grand Marquis GS
No name yet
Work In Progress
  #10
Old 08-03-2017, 07:04 AM
Svashtar's Avatar
Trader: (0)
Quote:
Thanks; I might have just tweaked something. I was under the rear end degreasing, scrubbing and hosing off the axle, diff, stud & girdle kit, RSB, everything, but was careful not to spray the bags. Nice and clean there now.
But I also read a post where a guys died after sitting for a long time. Mine didn't operate for a couple of weeks after years of working daily, so that might have done them in.
__________________
  #11
Old 08-03-2017, 07:39 AM
Trader: (2)
Sitting for a few weeks is nothing. That didn't "cause" them to go bad. Have you done the soapy-water test to see if the problem is actually the springs? Could be a leaking solenoid.
__________________
The Velvet Fog
No name yet
Work In Progress
  #12
Old 08-03-2017, 08:49 AM
Svashtar's Avatar
Trader: (0)
No, planned to do that this weekend to check the bags and lines. Didn't know about the solenoid so will have to see if I can eliminate or ID that as the problem. There's one for each side correct? Need to locate them.
Q: should I pull the fuse for the compressor in the meantime and just let it sag? It's running every few minutes now.
Thanks.
Norm
__________________
  #13
Old 08-03-2017, 04:01 PM
BAD MERC's Avatar
#2,187 out of 3,214
Trader: (3)
I have not done soapy water yet and will before I replace anything. However, if replacement is necessary I'll document the process and post it here.
__________________
#2,187 of 3,214
997 in Silver Birch
336 with sunroof
  #14
Old 08-03-2017, 07:45 PM
Trader: (2)
There's one for each side correct? Need to locate them. They're part of the air springs...right on top.
Just shut the switch in the trunk...
__________________
The Velvet Fog
No name yet
Work In Progress
  #15
Old 08-03-2017, 08:25 PM
Svashtar's Avatar
Trader: (0)
Air bags
Doh! Do you think?
Jesus, I'm getting senile...
BTW, I have this weird rubber stuff that says "Nitto" on it stuck to my rims...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Air bags BLACKMARAUDER04 Suspension & Brakes 2 08-28-2015 10:31 AM
HELP--Air Bags cruzer Community Discussion 5 09-04-2011 09:31 AM
Air bags paSS Suspension & Brakes 5 10-30-2010 11:32 AM
Air bags over inflated 03blackmerc Suspension & Brakes 9 02-08-2009 06:39 AM
Powered by: vBulletin
