MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Power Adders
Power Adders Look here for all your centrifugal, roots, supercharger, turbocharger and nitrous technical discussions regarding the Marauder!
Reply
Thread Tools Display Modes
  #1
Old 08-10-2017, 11:39 AM
Kdrzata34 Kdrzata34 is offline
Junior Member
Trader: (0)
Just got a Marauder! Need more HP!!!
Hello guys so i just got myself a marauder. it has a exhaust on it already from the previous owner. my goal for the merc is 400 rwhp and i want to know what is the easiest/cheapest way to do that? i plan on putting a ramair cai in it and adding 4.10 gears. but other than that im at a loss ive looked at superchargers, turbochargers, and prochargers and dont what would be the best move and i dont know what the stock internals could handle. so my goal is 400rwhp and how to get there easily.. any suggestions!?!
  #2
Old 08-10-2017, 11:44 AM
JBeezy's Avatar
JBeezy JBeezy is offline
300B
Trader: (4)
add Nitrous. Cheapest and easiest
Sent from my SAMSUNG-SM-G935A using Tapatalk
__________________
  #3
Old 08-10-2017, 11:53 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
boost.......stay 425 rwhp range with a good tune, stock stuff generally ok.
__________________
  #4
Old 08-10-2017, 12:29 PM
BUCKWHEAT's Avatar
BUCKWHEAT BUCKWHEAT is offline
Very Senior Member
Trader: (0)
On the stock engine, whatever you do, keep the WOT RPM's at and under 5800 & you should be OK on rods and pistons.
__________________
BUCKWHEAT 03 MM 300A-August, '02 mfgr, black w/ blue metallic clearcoat, 87,000 miles, Texid stroker 5.0, #15 Kool-Aide w/ SnakeBite porting, Venom cooling, and upgraded to M122 3873 of 7839
  #5
Old 08-10-2017, 12:30 PM
sailsmen's Avatar
sailsmen sailsmen is offline
Supporting Member
Trader: (1)
As stated above Laughing Gas all the way from the Bank.
__________________
  #6
Old 08-10-2017, 01:01 PM
Ambitious1's Avatar
Ambitious1 Ambitious1 is offline
Senior Member
Trader: (8)
Congratulations and Welcome!!! +1 on the boost.
  #7
Old 08-10-2017, 02:11 PM
Junior Member
Trader: (0)
thank you for the welcome and happy to be here!! im new to ford modular engines, this is really my first project car. so if i were to boost the car which is what i would like to do what would be best platform to do that. turbo? supercharger? ive done some research and read that an eaton supercharger would be a go way to go but im sure which one would be best m90, m112? ive also read that vortech makes a good ones as well. just like i said not sure which one to go with.. once i add the boost would i have to upgrade any of the supporting systems such injectors fuel pump intake manifold etc?
  #8
Old 08-10-2017, 02:51 PM
sailsmen's Avatar
Supporting Member
Trader: (1)
Go Laughing or you gonna break every piggy bank ever made.
__________________
  #9
Old 08-10-2017, 03:18 PM
Weißbirke Plünderer
Trader: (11)
the only off shelf supercharger avail. is a vortech system by ADTR.net.. $6500 plus installation. Eaton swaps are commn but you need to track down parts, it is not turnkey off a mustang. it needs specific marauder parts made or fabbed. its an m112. injectors, maf, fuel pump all need upgraded. eaton swap run $3500-$5000k in parts, install runs $1200-1700 ish. so you better have $5500-8000 avail. and be able to have the car down for a week or two.
__________________
  #10
Old 08-10-2017, 03:20 PM
Weißbirke Plünderer
Trader: (11)
do you have alot of miles on the current engine?
__________________
  #11
Old 08-10-2017, 03:42 PM
Junior Member
Trader: (0)
The engine has 115k on but the previous owner replaced the coils and spark plugs, also he replaced the timer chain and gears and he resealed it when had the engine out
  #12
Old 08-10-2017, 03:55 PM
guspech750's Avatar
guspech750 guspech750 is offline
V.I.P Parking for DTR's only!!
Trader: (4)
Here is a Trilogy kit for sale. Can't go wrong. Easiest way to get more HP and cheap too.
http://moddedmarauders.net/showthrea...percharger-Kit
Sent from The White House on taxpayers dimes.
__________________
Great quotes!!
Quote:
Originally Posted by CBT View Post
Quote:
Originally Posted by Haggis View Post
Eat poo poo and die heathen.
  #13
Old 08-10-2017, 04:11 PM
Lowndex's Avatar
Lowndex Lowndex is offline
Middle Age Crisis Member
Trader: (3)
Skip NOS and get a blower.
Mine has a Kenne Bell 3.2LC Mammoth. You need an 04 Cobra intake manifold and some plumbing.
  #14
Old 08-10-2017, 04:26 PM
Spectragod's Avatar
Spectragod Spectragod is offline
Willing to meet up half way
Trader: (45)
^^^THIS^^^
__________________
Trilogy # 192 / T.S. 0012
  #15
Old 08-10-2017, 08:26 PM
sailsmen's Avatar
Supporting Member
Trader: (1)
"...i want to know what is the easiest/cheapest way to do that?..".
Based on your above criteria equals Laughing Gas.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: vBulletin
