MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 08-11-2017, 04:43 PM
Geo's Avatar
Geo Geo is offline
Senior Member
Trader: (0)
tiny amount of grit in gerry can
so I've noticed a tiny bit of, what seems like, some dark grit, on the very bottom of my fuel gerry can.
Often I bring fuel to the car when it's stored off the road.
Is it advisable to ever put pressurized water in such a jerry can to attampt to dislodge such grit or is that a big no no.
I've never put water in a gerry can and something tells me not to even though it would dry out. I don't even know if that would remove the grit.
  #2
Old 08-11-2017, 04:53 PM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
Steam-cleaner. I've watched the techs at my favourite radiator shop steam clean a car's gas tank (out of the car, of course) prior to brazing holes.
__________________
  #3
Old 08-11-2017, 08:31 PM
sailsmen's Avatar
sailsmen sailsmen is offline
Supporting Member
Trader: (1)
Urine is an excellent cleaner for fuel tanks.
__________________
195,000 Miles & 275+ Runs Down the 1,320
Vortech Super Charger V-2 T Trim, 19 PSI
  #4
Old 08-11-2017, 10:55 PM
Svashtar's Avatar
Svashtar Svashtar is offline
Trying to get it right...
Trader: (0)
Sure, just use very hot water. That will clean then evaporate quickly. Turn it upside down and let it drain and air out for a day and you'll be good to go. Even cold water will work, just takes longer to dry out.
__________________
  #5
Old 08-12-2017, 02:05 AM
Marauderjack's Avatar
Marauderjack Marauderjack is offline
Senior Member
Trader: (13)
Rinse with 90% IPA after pressure washing with water!!
__________________
Member #1368
2004 Silver Birch...300A
#948 of 3213/#8787 of 11052
FIT "ProCharger" #0010
Real AutoMeter Oil Pressure Gauge
Addco Anti-Sway Bars
ScanGauge II In Dash
Nitto 295's On Widened Rears
Mach I Air Dam
  #6
Old 08-12-2017, 03:57 PM
Geo's Avatar
Geo Geo is offline
Senior Member
Trader: (0)
What exactly is IPA?
  #7
Old 08-12-2017, 03:59 PM
Geo's Avatar
Geo Geo is offline
Senior Member
Trader: (0)
Thank You. Will do.
  #8
Old 08-12-2017, 04:05 PM
jaywish's Avatar
jaywish jaywish is offline
Senior Member
Trader: (0)
India Pale Ale
__________________
03 MM, DPB, Charcoal, 6disk, HS, organizer, spoiler, Z&M arms, silverstars, oil deflector, U-Hall Tranny pan.
89 GM LS Colony Park, Mods-> HO, ss duals, HPP 16" rims, 225-60-16, hella H4 & H1 headlights, large frame 3g alt, rear auto air shocks, hd springs, rear police sway, alum driveshaft, 99 front and 03+ rear brake upgrade, tranny cooler, posi, winter boots= Town Car rims, 215-65-16 Goodyear Ultra GW3 Snows, Kenwood speakers, 93CV stereo.
  #9
Old 08-12-2017, 07:27 PM
Mr. Man's Avatar
Mr. Man Mr. Man is offline
GAME OVER, YOU LOSE!
Trader: (2)
Quote:
He said Jerry can not Jerry's can.
  #10
Old 08-12-2017, 07:52 PM
MyBlackBeasts's Avatar
MyBlackBeasts MyBlackBeasts is offline
T242 - Ricer ricer
Trader: (7)
Quote:
Isopropyl alcohol
Will eliminate water from the tank/can.
__________________
WLB
#2912 of 7093
Conceived 8/6/2002
Delivered 9/19/2002
Adopted 8/10/2011
Pioneer 6x8 Front
Legacy 600w 6x9 Rears
JL 6.5 SubWoofer
DR Deep Aluminum Trans Pan
Mo's Dyno Tune
Gorilla Nuts - The System
  #11
Old 08-13-2017, 07:27 AM
1Marauder's Avatar
Senior Member
Trader: (5)
Quote:
I see what you did there... very nice.
__________________
Tune, JLT, FlowMaster 42441 Res Delete, New Nitto 235/255 Bigcarsforever dead peddle & custom SRP peddles, 5 coats Zymoil Titanium, Addco front and rear sway bars, KYBs, 1/2 inch coil cut, Sparts Watts link and Control Arms, Car fixer alignment.
  #12
Old 08-14-2017, 10:23 PM
Geo's Avatar
Geo Geo is offline
Senior Member
Trader: (0)
looks like I will be blasting it with water and airing it out
  #13
Old 08-15-2017, 02:04 AM
Senior Member
Trader: (13)
Rinsing with IPA will speed the airing out process....a quart 90% IPA is pretty cheap!!
__________________
Member #1368
Mach I Air Dam
  #14
Old 08-15-2017, 09:07 AM
ByronRACE ByronRACE is offline
Senior Member
Trader: (1)
If you get it really clean with water and soap (no oils remaining) and air it out, it will flash rust if the inside coating is not intact. I would blast/clean it with water, but after that I'd drain it well, pour in 16oz of WD-40, slosh it around, and drain it back into my WD40 can to use later and remove water with a pipette or eye dropper. This is what WD40 was designed for; water displacement.
  #15
Old 08-21-2017, 02:04 PM
Geo's Avatar
Geo Geo is offline
Senior Member
Trader: (0)
Quote:
my gerry can is made of plastic not metal though
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Tiny pimples on my hood jimreed2160 Shop Talk 14 03-30-2016 04:06 AM
Gerry Goffin - R.I.P. fastblackmerc The Lounge 3 06-20-2014 07:10 AM
Tiny 2" mid pipes?? drhill Exhaust 14 02-08-2013 04:24 PM
Super Bee SRT-8 tiny morsel Bradley G The Lounge 22 11-28-2006 01:01 AM
Tiny Girlie Mercurys? Bobby Clobber Community Discussion 27 01-14-2006 06:11 PM
Powered by: vBulletin
