Need advice
Just what we were talking about; no one is detailed or can do their job anymore. I wouldn't touch a thing; leave the spring there. Take it back and point everything out to them and just ask them if this is their normal quality of work, because you're writing a yelp review and want to make sure.
If they can't be bothered to clean up after themselves and make the car look at least as good as when you brought it in, then they're hacks who don't deserve yours or anyone else's business.
Ask yourself if they would leave the stuff you can see in this condition, what they are doing with the work you can't see?
Unless they did the work for free, to me what you paid isn't a factor.
If they listen and respond to you then they deserve your trade. If they don't, then you've lost nothing by trying.
