Results 1 to 3 of 3
Thread: 2001 CV wiring help
    2001 CV wiring help
    Hi guys...
    I need help with my stepson's 2001 Crown Vic trunk wiring.
    My 2003 Shop Manuals are at my brother's house with my Marauder....
    I'm looking for a switched 12VDC source in the trunk.
    I found an unused plug/connector on the left hand side of the trunk near the fuel pump reset switch that has a switched 12VDC wire (dark green/yellow stripe as best as I can tell).
    Weird thing is that the wire still shows .25 -> .30 VDC with the ignition off....?
    Is that connector for the air ride suspension on air ride equipped cars?
    Thanks in advance for your help.
    Timbuk3, MI
    Arrow
    For your listening pleasure and reading enjoyment ...
    Oct 2005
    Southwest Florida, Lee County
    Depending of what you need the power for, I would hesitate tapping into anything unless it's to trigger a relay or solenoid. There's also THREE different types of switched power; Accessory which is hot in ON and ACC (radio, wipers). Ignition which is hot in KEY ON and CRANK (Fuel, PCM) , and accessory which is hot only in KEY ON but dead during crank (HVAC). I would suggest running a fused wire from the steering column or from behind the radio (ACC). I wish I could help more.
    2004 Mercury Marauder
    2,187 of 3,214
    997 in Silver Birch
    448 with light flint interior
    304 with heated seats
    336 with sunroof
  1. For Sale 2003 Ford Factory SERVICE MANUAL & WIRING MANUAL , 2004 WIRING MANUAL
    By larryo340 in forum Marauder-specific Parts for Sale
    Last Post: 07-09-2017, 12:25 AM
  2. For Sale 2001 triumph tt 600
    By LOWBUCKMM in forum Other Cars for Sale
    Last Post: 08-15-2011, 06:57 PM
  3. 2001 kb cv sc
    Last Post: 11-01-2009, 06:13 PM
  4. I Just Saw A 2001 Marauder !!!!
    By revereamg in forum Community Discussion
    Last Post: 03-17-2007, 10:42 PM
  5. Need 2001 GMC chip
    By drgnrdr33 in forum The Lounge
    Last Post: 12-01-2004, 06:57 PM
