Anyone know why one should balance pistons separate from pins??
If the set I have are within .8g, could I not simply remove some of the piston and pin material and make the one piston/pin set within .5g to the others?
This has me curious...
Balancing an engine is extremely crucial for maximum efficiency and smoothness. A half a gram doesn't seem like much but sling it back and forth 7000 times in a minute and it ends up becoming LOTS of weight. http://www.hotrod.com/how-to/engine/...ine-balancing/
2004 Mercury Marauder
2,187 of 3,214
997 in Silver Birch
448 with light flint interior
304 with heated seats
336 with sunroof
never heard the need for this. If you were to weigh each pin and determine they are all dead equal, you could just mix and match to balanced pistons.
Otherwise:
keep the pin/piston/rings & retainer clips together per bore installed, and remove material from the piston skirts/meatey area under the pins of the heavier ones to achieve within .5g each.
Same with the rods/bearings.
Try not to attach the furthest out of pistons and rods - use a paper to write down results, and combine rod weights with piston weights to get the best stacked weight combination.
Time spent on this makes the difference of a good engine and an awesome freaky good one
2004 SILVER BIRCH/BLACK PAINT
DARK CHARCOAL NUDO LEATHER
#400 of 997 (SOLD)
2004 CV LX SPORT
2004 300A MM BLACK
1 OWNER CAR, NO OPTIONS
DAILY DRIVER
2013 DAYTONA R/T
SUPER TRACK PACK
DAYTONA BLUE PEARL
#1763 off ~2100
NOW WITH A 392 & 3.73 posi!
