MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Suspension & Brakes
Suspension & Brakes Post your discussions about suspension, shocks, control arms and brakes here!
Reply
Thread Tools Display Modes
  #1
Old 10-13-2017, 06:12 AM
Drewstang's Avatar
Drewstang Drewstang is offline
Junior Member
Trader: (1)
VAPS Issues, the final straw
I bought the car with an inactive VAPS. I've been dealing with it for a while but I recently rebuilt the front suspension and ordered a no name reman rack on ebay (I know.) After changing the rack and putting everything back together I still have no VAPS.
I bought a known good module from a member here and swapped that in with no luck. I googled a VAPS check and found a step by step guide from a Ford tech that verified the rack was getting signal from the module and the module was getting power. I then used our Matco scanner to verify the module was getting input from the optical sensor and the OSS in the trans, which it was. I told the seller of the reman rack I believe it was not operational and they sent another. Instead of getting another alignment I swapped the VAPS solenoid from the second rack onto mine. After topping off the fluid and putting it back together I had VAPS for all of 30 seconds and it was gone again.
Has anyone else had any similar issues before I drop $500 on a Motorcraft reman unit?
__________________
03 Marauder- 300A, Eaton Swapped, current whip
03 Marauder- 300A, 5544 of 7839 in 03, Trilogy #24, SOLD
04 Marauder- 300B, SB with LF interior, 208k miles and still ticking SOLD
  #2
Old 10-19-2017, 05:20 AM
Drewstang's Avatar
Junior Member
Trader: (1)
Ordered a Cardone reman rack 22-270. This rack does not come with the EVO / VAPS solenoid for future reference. They list a rack 22-249E for the GM / CV with VAPS but the specs from the Cardone show the pressure is lower on the GM / CV rack by 200 psi. The EVO / VAPS solenoid is not available separate from them. A thread on CVN had talked about ordering one from Detroit Axle as they are a supplier for reman units, but I can't get them to return my call about availability or pricing. My patience with this is done. I ordered a reman unit from the local Ford Dealer this morning. Will update after I install.
__________________
  #3
Old 10-21-2017, 04:01 PM
alec2538 alec2538 is offline
Senior Member
Trader: (0)
How do you know if it's working or not?
I've still got the original rack in mine, 213k miles. Feels great to me, can't honestly say I feel much difference between low speed/in town driving and highway curves.
  #4
Old 10-23-2017, 07:53 AM
Drewstang's Avatar
Junior Member
Trader: (1)
I had no power assist at low speeds, others report power assist at all speeds making highway driving touchy and dangerous.
This system uses input from the output shaft speed sensor in the transmission along with the optical sensor in the steering column to send a variable signal to the solenoid on the steering rack. This will increase steering effort with vehicle speed and decrease accordingly.
My car is now fixed. I installed a reman Ford rack and a reman Cardone pump just to rule everything out. I should be good for another 200k or so.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wanted To Buy 2003 MM Air Ride / VAPS module Drewstang Marauder Parts/Misc. Wanted 1 10-04-2017 08:15 AM
Wanted To Buy VAPS unit Ourobos Marauder Parts/Misc. Wanted 9 12-05-2015 04:19 AM
Wanted To Buy **WANTED** VAPS/RAS Module SAAAAAC Marauder Parts/Misc. Wanted 11 09-04-2015 06:34 AM
Wanted To Buy VAPS/RAS module MustangMoser Marauder Parts/Misc. Wanted 0 12-12-2014 01:51 PM
Abs and vaps Coupe Suspension & Brakes 18 01-04-2012 12:53 PM
Powered by: vBulletin
