MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 10-22-2017, 05:39 AM
sailsmen's Avatar
sailsmen sailsmen is offline
Supporting Member
Trader: (1)
Purchasing Parts - Note Quantity
I had previously ordered clips from Ford. The Ford P/N is 4 clips to a Ford Parts Bag.
I reordered from a Ford Dealer using the same P/N. I open the box and the Ford Dealer tore open the Ford Parts Bag and "removed" 3 clips! Although the P/N is 4 clips they "sold" me 1 clip.
When ordering by part number do not assume thats what you are ordering!
__________________
  #2
Old 10-22-2017, 05:44 AM
sailsmen's Avatar
Supporting Member
Trader: (1)
I argued with the Dealer and their response was "We only sell one clip".
Part of the problem is they use the Ford P/N, Ford description and Ford graphics.
I told them the fact that they tore open the Ford Parts Bag and "removed" 3 speaks for itself.
__________________
  #3
Old 10-22-2017, 07:35 AM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
I've ran into this myself locally with O rings. They claim the part # is per piece just like a case of four gallons of paint..
Good thing the grocery store doesn't open your case of beer!
__________________
  #4
Old 10-22-2017, 07:59 AM
JimP's Avatar
JimP JimP is offline
Senior Member
Trader: (0)
Whenever possible avoid the stealership.
__________________
1987 GN running 10's. 2003 MM Blue Sold and dearly missed!
2003 Black 300B
Procharger P1sc with air to air intercooler
3,000 PI converter
4.10 Eaton posi 31 spline carrier
Moser 31 spline axles
Koos headers, with custom stainless exhaust, Megs tips
Carbon fiber drive shaft
Metco control arms
Every autometer procomp gauge in the catalogue
  #5
Old 10-22-2017, 08:02 AM
Fastbob's Avatar
Fastbob Fastbob is offline
Senior Member
Trader: (0)
As a former Ford parts counterman.... your dealer was correct. They come in a package of 4, but they are sold as each. If they order a quantity of 1 they get a package of 4 in this example and they have available a quantity of 4 to sell.
__________________
2004 SB #2150 of 3214 Moonroof, Heated Seats and 6 CD Changer. Non OEM Mufflers and 31,XXX miles and counting.
  #6
Old 10-22-2017, 08:18 AM
sailsmen's Avatar
Supporting Member
Trader: (1)
Quote:
When ordered directly from Ford and picked up at my local Dealer they come in a sealed Ford Parts Bag as a set of 4. Ford sells them as a set of 4.
If the Dealer is going to;
1) use the same Ford P/N
2) Ford Graphics
3) tear open the Ford Parts Bag removing 3.
Then the Dealer needs to make it clear they are only selling 1 piece.
__________________
  #7
Old 10-22-2017, 08:22 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
buy from here when can..
http://www.clipsandfasteners.com/default.asp
__________________
  #8
Old 10-22-2017, 09:03 AM
Svashtar's Avatar
Svashtar Svashtar is offline
Trying to get it right...
Trader: (0)
How the dealer could rationalize out of the words “One package 4 pcs” on the unopened package is beyond me. The fact that he tore it open to show 3 is proof that they shorted you one in the bag. If they are sold “as each” then they should come wrapped individually for sale “as each,” priced accordingly, and you should have had to buy four bags to get what you need.
I love how the dealer falls back on the individual method of sale to justify the clear bagging mistake.
Clever guy pulling that fact out of his ass on the fly like that at the last second, but his argument is irrelevant to the error.
P.S. BTW, these are the clips for the radiator cover?
__________________
  #9
Old 10-22-2017, 09:40 AM
MyBlackBeasts's Avatar
MyBlackBeasts MyBlackBeasts is offline
T242 - Ricer ricer
Trader: (7)
Order from Amazon, at least they are quantity honest. $1 each then get a quantity number sufficient to make the $4 shipping worth it.
https://www.amazon.com/Ford-W706519-...ds=W706519S300
Or get a pkg of 10 from aftermarket - just as good or better quality as OEM fot $15 with free shipping.
https://www.amazon.com/Radiator-Sigh...ds=W706519S300
__________________
WLB
#2912 of 7093
Conceived 8/6/2002
Delivered 9/19/2002
Adopted 8/10/2011
Pioneer 6x8 Front
Legacy 600w 6x9 Rears
JL 6.5 SubWoofer
DR Deep Aluminum Trans Pan
Mo's Dyno Tune
Gorilla Nuts - The System
  #10
Old 10-22-2017, 09:43 AM
T242 - Ricer ricer
Trader: (7)
Did they charge you $16 or $4?
__________________
WLB
#2912 of 7093
Conceived 8/6/2002
Delivered 9/19/2002
Adopted 8/10/2011
Pioneer 6x8 Front
JL 6.5 SubWoofer
Mo's Dyno Tune
  #11
Old 10-22-2017, 09:48 AM
fastblackmerc's Avatar
Trader: (75)
Got plenty of these. New. I charge per piece.
__________________
  #12
Old 10-22-2017, 08:23 PM
larryo340's Avatar
larryo340 larryo340 is offline
Now Marauderless :(
Trader: (3)
+1
It sounds like b.s. but it’s not...that’s the way Ford Motor lists and sells some parts to the dealer.
__________________
  #13
Old 10-22-2017, 09:15 PM
Svashtar's Avatar
Trader: (0)
Quote:
Originally Posted by larryo340 View Post
+1
Ok, sure, I don’t think anyone is disputing that now that it’s been explained.
What’s in question is the fact that the bag says “one package of 4 pcs,” and it has 3 pieces in it. How Ford chooses to sell those individually is irrelevant. The bag is either mislabeled, or short 1 piece. Either way they owe a clip to Sailsmen.
__________________
  #14
Old 10-22-2017, 11:00 PM
Logizyme's Avatar
Logizyme Logizyme is offline
Senior Member
Trader: (2)
Yeah I would just say be grateful that they offer that.
If each individual clip is $4, and you walk in and ask for 3 clips, they could:
A. Tell you, you have to buy a package of 4 clips, its $16
B. Sell you three clips without the packaging for $12
Which is cheaper for the number of clips you needed.
Generally, my dealer will hold the packaging for any remaining pieces they are keeping in stock so that there are not loose random pieces without part numbers rolling around, so I would consider you further lucky that they were providing you with the packaging for a single clip.
Now it does sound like there was some miscommunication between you and the dealer - most of your front counter people are not the brightest, so I would not be surprised if it was their fault. But if you looked up the number, found out yourself it was a package of 4, called them and asked for one, that sounds like it is on you - in the dealership's inventory system, one is one clip, saving you the 12$ difference between one sell pack.
__________________
  #15
Old 10-22-2017, 11:52 PM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (39)
The dealer is correct. The end
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
General parts purchasing mm svt Shop Talk 29 03-08-2017 01:51 PM
Found one that I actually may be purchasing! jmsa540 Community Discussion 28 11-29-2014 09:54 PM
Purchasing CAI Finally JLT Performance 4 03-20-2014 08:58 AM
What to Look For In Purchasing Used Marauder 93flareside Community Discussion 12 08-21-2013 08:11 AM
Thinking of Purchasing a Crown Vic Stillen GLE Shop Talk 52 02-16-2010 06:02 PM
Powered by: vBulletin
