MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Interior Electrical/Electronics
Interior Electrical/Electronics This is the place for questions/discussions of head units, speakers, navigation systems, alarm systems, heated seats, rear window defoggers, door locks, air bags, etc.
Reply
Thread Tools Display Modes
  #1
Old 10-22-2017, 01:51 PM
Jaguar Jaguar is offline
Member
Trader: (0)
Tip for anyone wanting to add an aux port
I finally got tired of burning CDs and investigated adding an aux port to the stock radio. I didn't want to buy a whole new radio and I wanted to keep the stock look. I found there are boxes that plug into the back of the radio, like the PIE, but they require cutting out some material behind the dash to fit. I wasn't keen on cutting even non-visible parts of the car.
It's also possible to add an aux port on the front of the radio if you don't mind drilling a hole and soldering. There are people that will do this mod for you too on eBay. Again though I didn't like the thought of drilling into my radio.
I decided not to bother at all with the aux port and skip straight to Bluetooth. Apple infamously removed the aux port on the last iPhone. Google has done the same now with the Pixel. I expect the trend to continue and the future is going to be wireless connections.
I opted for a Bluetooth FM transmitter that plugs into the cigarette lighter instead. It's more annoying to work with than aux since it's not as simple as plugging in a wire, but that's the future
I tried one of those tape deck to 3.5mm adapters too and the audio quality was terrible. The FM transmitter sounds far better.
  #2
Old 10-22-2017, 02:26 PM
1stMerc's Avatar
1stMerc 1stMerc is offline
Senior Member
Trader: (1)
Get one of these. Works great.
https://www.gogroove.com/flexsmart-x...fm-transmitter
and this
https://www.android.com/auto/
__________________
Born 03/04
Adopted on 01/03/05
Now Procharger boosted #04
  #3
Old 10-22-2017, 02:58 PM
stevengerard stevengerard is offline
Senior Member
Trader: (0)
there is also a blue tooth cassette tape that works great.
__________________
Steven
2004 Marauder Black, loaded
Vortec S/C
4.10s
3500 PI Stall
Kook's headers
476.9 rwhp 385 lbs/tq
Lidio tune
2004 Suburban Dark Charcoal
  #4
Old 10-23-2017, 12:28 AM
MunsterBro95's Avatar
MunsterBro95 MunsterBro95 is offline
Senior Member
Trader: (0)
Quote:
I had the Bluetooth cassette. It was pretty good.
  #5
Old 10-23-2017, 07:36 AM
martyo's Avatar
martyo martyo is offline
MO derator
Trader: (27)
Just put in a JVC 820BT or 830BT
By the time you’re done with all the work around you could have a radio you’ll enjoy.
__________________
  #6
Old 10-23-2017, 10:27 AM
Member
Trader: (0)
I opted for this FM transmitter. If the LEDs were green instead of blue, it'd be perfect and almost look stock. It's the same size as the battery/oil gauges.
  #7
Old 10-23-2017, 10:44 AM
510paesan's Avatar
510paesan 510paesan is offline
Senior Member
Trader: (0)
http://www.1factoryradio.com/ford-tr...f2f-18c868-aa/
Found this company some time back. This retains stock look with Bluetooth compatibility
  #8
Old 10-23-2017, 11:33 AM
fastblackmerc's Avatar
Trader: (75)
General Features:
DVD/CD receiver with AM/FM tuner
built-in internal amp (22 watts RMS/50 peak x 4 channels)
6.8" Clear Active touchscreen (6.2" inset QVGA display for video)
variable color illumination and control layout
fits double-DIN dash openings
wireless remote
Smartphone Features:
built-in iPod, iPhone, and iPad control (see Details tab for model compatibility)
works with Apple CarPlay
Pandora and iHeartRadio control with iPhone and Android; Apple Music control with iPhone
built-in Bluetooth for hands-free calling and audio streaming with dual phone connection
Audio/Video Features:
plays CDs, DVDs, and USB memory devices (see Details for full capabilities)
13-band equalizer with digital time alignment
K2 technology improves the digital sound for all music sources
Sound Lift compensates for low speaker positions
Volume Link EQ boosts specific frequencies to compensate for road noise
subwoofer level, phase, and low-pass crossover controls
Expandability:
compatible with SiriusXM satellite radio tuner
inputs: rear USB input, rear A/V input, rear-view camera input
outputs: rear video output, 6-channel preamp outputs (4-volt front, rear, subwoofer)
Other Information:
compatible with most factory steering wheel audio controls (adapter required)
works with iDataLink Maestro moduleretains Ford SYNC, GM OnStar, Chrysler Uconnect, and VW media center
displays engine performance data on touchscreen
__________________
  #9
Old 10-23-2017, 12:17 PM
akr619 akr619 is offline
Senior Member
Trader: (0)
casette bluetooth i havent tried but the corded casette works perfectly. its great to keep your OEM look.
__________________
Performance Transmission with 3200 Converter from PATC in Louisiana in 2011
B&M Transmission cooler with Thermostatic controlled Fan, along with A Pillar Temp Gauge (Plus to other Gauges)
K&N FIPK
Addco front and Rear anti sway bar upgrades
Pauls HP Intake Spacer
Full Performance Exhaust Custom done by Miami Muffler, with full Mandrel Bent 2.5 inch pipe, With Aero Turbine 2525 Mufflers, Kooks Long-Tube Headers and 3.5inch Stock Like Chrome Tips
Upgraded Brake Rotors, and High Speed Pads
HID Upgrade on Headlights
Power Acoustic Single DIN bluetooth head With Pioneer Speakers throughout and MB quartz tweeters
Kicker 4 Channel and Kicker 2 Channel Amp Mounted in trunk Organizer out of the way.
Kicker L7 10inch Solobaric in 3/4cu/ft box in place of factory Sub Woofer
  #10
Old 10-23-2017, 04:11 PM
Member
Trader: (0)
I must have had a cheap cassette converter. The one I had sounded terrible. I also didn't like that the cassette motors were continually running. It seemed like a recipe for failure (more heat being generated and the motors won't last forever).
I found a bluetooth adapter with green LEDs. I should have gone with that instead. Oh well.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
New guy wanting a MM InfernoHeat2005 Welcome Forum 31 09-11-2011 02:30 PM
wanting to mod my vic 1320ft Capital Area Marauders 45 09-08-2010 04:07 PM
Wanting to jump in but The Great Tuning 2 04-28-2010 08:07 AM
Been wanting a DSLR? CRUZTAKER The Lounge 9 11-29-2006 01:15 AM
Wanting to get a CB or the like KillJoy The Lounge 10 03-06-2006 08:55 PM
Powered by: vBulletin
