MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Wash, Wax and Detailing
Wash, Wax and Detailing Share your best tips and tricks about giving the Marauder that winning car show look.
Reply
Thread Tools Display Modes
  #1
Old 10-22-2017, 05:18 PM
Jacob's Avatar
Jacob Jacob is offline
Junior Member
Trader: (0)
Water Etched Windows
All of the windows in my 2003 marauder are all water etched. I can’t find a way to get them clean. I have tried polishing them with a da and megabits m105, vinegar and #0000 steel wool and nothing helped at all, the still look as bad as when I started. Does anyone have any suggestion?
File Type: jpg E0B010CA-B6ED-4944-8CBF-97C0599D0811.jpg (91.4 KB, 78 views)
File Type: jpg FEA59E47-72A7-40F1-A333-B71A953F4CFD.jpg (85.1 KB, 72 views)
  #2
Old 10-22-2017, 05:24 PM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
try this, it works good for removing built up road grime that car soap does not etc...found in cleaners section at grocery..sponge and some elbow grease, a little water..make a paste..smaller area at a time. rinse well
__________________
  #3
Old 10-22-2017, 05:35 PM
Spectragod's Avatar
Spectragod Spectragod is offline
Willing to meet up half way
Trader: (45)
If the above doesn’t work, you may want to give a glass company a call, or a detail shop, last choice a place that cleans windows commercially. By the look of it, it appears etched in, good luck.
__________________
Trilogy # 192 / T.S. 0012
  #4
Old 10-22-2017, 05:48 PM
Jacob's Avatar
Junior Member
Trader: (0)
Yah. Hopefully that works. Thanks for the replies
  #5
Old 10-22-2017, 06:47 PM
camelgrundle's Avatar
camelgrundle camelgrundle is offline
the grundle always gets ya
Trader: (4)
Zero deductible glass and a baseball bat. Boom!
__________________
300A Black
  #6
Old 10-22-2017, 07:40 PM
MyBlackBeasts's Avatar
MyBlackBeasts MyBlackBeasts is offline
T242 - Ricer ricer
Trader: (7)
You might want to confirm if it's not lime spots 1st.
Use 50/50 white vinegar & water, soak a paper towel and lay on the window. Keep wet with solution for 10 minutes and remove and immediately wash the window. If "etching" is gone in that spot then it's not etching, it's lime spots. Repeat using an old towel instead of paper towel to cover a larger area.
__________________
WLB
#2912 of 7093
Conceived 8/6/2002
Delivered 9/19/2002
Adopted 8/10/2011
Pioneer 6x8 Front
Legacy 600w 6x9 Rears
JL 6.5 SubWoofer
DR Deep Aluminum Trans Pan
Mo's Dyno Tune
Gorilla Nuts - The System
  #7
Old 10-23-2017, 02:16 AM
Marauderjack's Avatar
Marauderjack Marauderjack is online now
Senior Member
Trader: (13)
Get this stuff from Walmart.......apply with sponge rinse and water spots are GONE!!
https://www.walmart.com/ip/Whink-Rus...FL-OZ/21798682
__________________
Member #1368
2004 Silver Birch...300A
#948 of 3213/#8787 of 11052
FIT "ProCharger" #0010
Real AutoMeter Oil Pressure Gauge
Addco Anti-Sway Bars
ScanGauge II In Dash
Nitto 295's On Widened Rears
Mach I Air Dam
  #8
Old 10-23-2017, 08:46 AM
stevengerard stevengerard is offline
Senior Member
Trader: (0)
Bon Ami works great as well
__________________
Steven
2004 Marauder Black, loaded
Vortec S/C
4.10s
3500 PI Stall
Kook's headers
476.9 rwhp 385 lbs/tq
Lidio tune
2004 Suburban Dark Charcoal
  #9
Old 10-23-2017, 09:06 AM
Senior Member
Trader: (13)
If the glass is pitted and you really wanna polish it use Cerium Oxide some water and a high speed buffer but be warned it is VERY MESSY!!
__________________
Member #1368
Mach I Air Dam
  #10
Old 10-23-2017, 10:03 AM
Joe Walsh's Avatar
Joe Walsh Joe Walsh is online now
STILL N/A
Trader: (7)
Quote:
Yes....."large stone hit windshield in road construction area"...
Bingo...brand spanking new windshield!!
__________________
2003 Mercury Marauder FI. 4 speed Auto*
2017 Ford Fusion Sport DFI. Twin Turbo V6 6 speed Auto
1985 Mustang GT 5.0 Hatchback 4bbl 5 speed manual
1965 427 Cobra (ERA) 468 all Aluminum FE 2x4bbl 5 speed manual
*Crower Cams & Springs, +1mm SS valves, mild port job on the cylinder heads.
PIAA Headlights & Fog Lights
Built: 10/15/02 Bought: 12/16/02
  #11
Old 10-24-2017, 04:12 AM
marauderrocks51 marauderrocks51 is offline
Senior Member
Trader: (0)
if you can find RARE OX , it was used long ago buy a glass shop in Chicago . they said it was the best for polishing glass . that's all the info I have . maybe its still around.the complete name is Rare Earth cerium oxide glass polish
  #12
Old 11-03-2017, 08:17 PM
Jacob's Avatar
Junior Member
Trader: (0)
Sorry i have been super busy and haven't been able to try any of these. thank you all for all go the replies i will do my best to try them in the near future and let you guys no if it works.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Windows 7 DTRMiguel The Lounge 15 11-13-2009 03:14 PM
Windows 7 for $29.99! MM2004 The Lounge 1 09-21-2009 09:25 AM
HELP!! (I don't do windows) Professor Community Discussion 12 08-19-2007 03:56 PM
Is your Marauder vin etched? Bradley G Community Discussion 15 01-12-2007 10:46 PM
Water, Water Everywhere ........ in NoVA Bluerauder The Lounge 18 06-30-2006 06:37 AM
Powered by: vBulletin
