Brake bleeding question
As long as I'm replacing the rotors and calipers, I was going to bleed out the old original brake fluid. Plan was to start at the right rear, then left rear then move up to the front. (This assumes the ABS isn't mounted in the rear...)
My question is do I need to do anything with the ABS itself? I understand it requires a shop to bleed it? Is there a sensor I need to disconnect, or can I just bleed the 4 lines as normal?
Some say you need to change out the brake fluid every 2-3 years; I don't know about that, but at 14 years and 113K it seems like s good idea.
Thanks for any info on the ABS.
