MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 07-11-2018, 04:57 AM
crownvic05 crownvic05 is offline
Senior Member
Trader: (7)
voltage issue with A/C?
Ok, so im posting this here because CVN is having issues with new post. Maybe someone here can help me resolve this. Its not a marauder but a 2005 crown vic lx sport.
Issue im having is that when driving with A/C off, all works great and normal like it should. When driving with A/C on and I come to a stop at a light, voltage drops from 14 to 13 in one shot and car some surges/hesitates. It rapidly goes back up to 14volts. This happens everytime I come to a stop.
Is this issue related more to compressor problem or something else?
  #2
Old 07-11-2018, 08:12 AM
fastblackmerc's Avatar
fastblackmerc fastblackmerc is online now
Trader: (75)
The A/C compressor might be locked up. With the A/C off the compressor clutch free wheels. With the A/C on the clutch is engaged and if the compressor is locked up it might be causing the problem.
__________________
  #3
Old 07-11-2018, 08:31 AM
Turbov6Bryan's Avatar
I miss whitey here
Trader: (5)
Does it do it in park? Vs in gear?
Pop the hood and check battery connections, how well does it idle ?
__________________
04 DTR
03 Black 300A
03 Black 300A
03 C.V. Sport Silver Frost
04 Supercharged SILVER BIRCH
04 SILVER BIRCH NA
  #4
Old 07-11-2018, 09:05 AM
Senior Member
Trader: (7)
wouldn't a locked compressor cause bigger problems like maybe snapping belts or unable to start car?
  #5
Old 07-11-2018, 10:10 AM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
What happens if you put the car in gear, foot on the brake, THEN turn on the A/C?
__________________
  #6
Old 07-11-2018, 10:16 AM
Trader: (75)
It's possible. You need to do some more PD.
Could also be bad / loose / corroded + & - connections.
__________________
  #7
Old 07-11-2018, 10:31 AM
I miss whitey here
Trader: (5)
Does it still do burnouts?
Problem solved!
__________________
04 DTR
03 Black 300A
03 Black 300A
04 SILVER BIRCH NA
  #8
Old 07-11-2018, 10:40 AM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
Sounds like a weak alternator not keeping up with the draw of the A/C. Mine dips to 12 flat with A/C, stereo, lights, and perhaps lower yet with anything else. Been that way for a couple of years and never once failed to start even with my hi torque starter. Mine doesn’t hesitate at all but gives off a neat cam surging idle the more I stress the voltage LOL
__________________
  #9
Old 07-11-2018, 04:10 PM
Senior Member
Trader: (7)
So when in parked and ac on, everything is good. If i put the car in drive with ac on, everything is good. When i put car in reverse with ac on, volt dips from 14.2 to 13 then moves back up slowly. With ac on everytime i hit a red light, volt dips to 13 and slowlyback up to 14. With ac off, none of this happens.
So all of this issue happens with ac on. Only time ac and voltage is fine is when in parked.
  #10
Old 07-11-2018, 04:26 PM
Invective's Avatar
Invective Invective is offline
Supporting Member
Trader: (4)
Car starts? A/C blowing cold? No strange noises? I think you're good. It's a machine - don't let it drive you nuts.
__________________
Current Garage:
2004 DTR Marauder
2005 Mustang GT Premium
2006 Ranger XLT Extended Cab 4 Door 4.0L 4WD
2008 Triumph Sprint ST
2015 Triumph Trophy SE
“Only those who play to win. Only those who risk to win. History favors risk-takers. Forgets the timid. Everything else is commentary.” – Iveta Cherneva
  #11
Old 07-11-2018, 05:44 PM
Trader: (2)
There's a function in the PCM that's supposed to goose the RPM slightly when the compressor is commanded on to mitigate the additional load. Try disconnecting the battery for a few minutes and see if that clears anything. Other than that, I'm outta idears.
__________________
  #12
Old 07-11-2018, 06:43 PM
Senior Member
Trader: (7)
Drives me nuts because this is not how car was running until 2 weeks now. So something is going to happen eventually.
  #13
Old 07-11-2018, 06:49 PM
Invective's Avatar
Supporting Member
Trader: (4)
You may not discover the issue until an obvious failure takes place. Then, it will be easier to diagnose and repair - no need in stressing out about something you really don't have control over at the moment. Just let the situation develop and just kick back with your favorite beverage....
__________________
Current Garage:
2004 DTR Marauder
  #14
Old 07-11-2018, 08:04 PM
justbob's Avatar
Sick-Speed play toy
Trader: (11)
Quote:
Like at night on the side of the road?
He has plenty of control right now. Diagnosing is typically easier in the comfort of your garage. With tools.
__________________
  #15
Old 07-12-2018, 02:50 AM
Invective's Avatar
Supporting Member
Trader: (4)
Philosophers through the ages have grappled with the age old question: Why do machines sometimes do weird stuff? Their collective conclusion: @$#%&*%&$#@$!
__________________
Current Garage:
2004 DTR Marauder
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LCM issue or wiper board issue? Video included Turbov6Bryan Shop Talk 16 05-25-2016 12:00 PM
PATS issue? LCM issue? Help me diagnose Mebot Shop Talk 8 04-13-2015 06:34 PM
Voltage Drop on Acceleration Issue bones Shop Talk 22 11-09-2009 04:35 PM
Voltage issue... whtknt2 Shop Talk 29 09-14-2009 06:25 PM
WOT and voltage Donald Community Discussion 6 08-24-2003 11:08 AM
Powered by: vBulletin
