MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Transmissions
Transmissions This forum is to exchange information about the 4R70W & 4R75W transmissions.
Reply
Thread Tools Display Modes
  #1
Old 12-29-2016, 10:27 PM
JBeezy's Avatar
JBeezy JBeezy is offline
300B
Trader: (4)
Mechanical or Electrical Trans. Temp Gauge?
I've decided to simply go with a transmission temp gauge. Just wondering which would be the best? Also where should install the sensor on either. Thanks in advance
Sent from my SAMSUNG-SM-G935A using Tapatalk
__________________
  #2
Old 12-29-2016, 10:39 PM
MOTOWN's Avatar
MOTOWN MOTOWN is offline
S/C 20" MINI TUBBED WHEEL GUY!
Trader: (46)
Go with an Auto meter electrical gauge, install the temp sensor in the test port on the drivers side of the trans near the linkage.
__________________
ITS ALIVE !!!!!!!!
STAY TUNED!!!!!!!!!!
  #3
Old 12-30-2016, 02:13 PM
JBeezy's Avatar
300B
Trader: (4)
Thanks!!
__________________
  #4
Old 12-30-2016, 03:06 PM
massacre massacre is offline
Senior Member
Trader: (6)
My trans pan has a port in the front for a temp sender
__________________
Million Dollar Aero
  #5
Old 12-30-2016, 03:52 PM
JBeezy's Avatar
300B
Trader: (4)
Quote:
That would be nice
__________________
  #6
Old 12-30-2016, 03:53 PM
JBeezy's Avatar
300B
Trader: (4)
Seems like I read where the test port location wouldn't give an accurate reading. May have been on an F-150
__________________
  #7
Old 12-30-2016, 04:33 PM
MOTOWN's Avatar
Trader: (46)
I've used both the pan port and the test port , there was absolutely no difference.
__________________
ITS ALIVE !!!!!!!!
  #8
Old 12-30-2016, 06:39 PM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
Test port is post converter and can average 30* higher than a pan temp. I think this is a good thing and my preference.
__________________
  #9
Old 12-30-2016, 06:48 PM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
Quote:
Lidio told me the same thing when I had him install the trans temp gauge while there for a dyno-tune. He put an Autometer manifold in the outlet line to the trans cooler, saying it's best to measure at the hottest point.
__________________
The Velvet Fog
2000 Grand Marquis GS
No name yet
Work In Progress
  #10
Old 12-31-2016, 08:02 AM
Turbov6Bryan's Avatar
meow meow meow
Trader: (4)
B&M Deep pan on eBay. 4 hours left
https://www.ebay.com/itm/371824445808
__________________
  #11
Old 12-31-2016, 09:58 PM
JBeezy's Avatar
300B
Trader: (4)
Bryan, I missed it. Thanks for sharing
__________________
  #12
Old 01-01-2017, 01:08 PM
tbone's Avatar
tbone tbone is offline
The Interceptor
Trader: (3)
Mounted mine in my B&M deep pan. No wonder it never goes over 150 degrees. Works for me. I can add 150 to 30 in a reasonable period of time.
  #13
Old 01-01-2017, 03:05 PM
MOTOWN's Avatar
Trader: (46)
Ill say it again , having had the temp sensor mounted in the test port location , and then moving it to the trans pan so the forced lube tailshaft mod could use the test port , there was absolutely no difference in trans temps let alone a 30* difference!
__________________
ITS ALIVE !!!!!!!!
  #14
Old 01-01-2017, 03:09 PM
EMAS EMAS is offline
Senior Member
Trader: (0)
Quote:
And the reality it that what really maters is if it varies from whatever is the norm for your car in the location your sender is mounted.
  #15
Old 03-19-2017, 09:54 AM
JBeezy's Avatar
300B
Trader: (4)
Finally got around to installing the gauge before dark yesterday. I'll have to go out and see why the color of the 2 gauges are so different. Both have green covers over the bulbs.
The temp reading is after 30 min of driving and a quick illegal drag race from a stop light with a 2005 Mustang GT. Appears the temp reading is around 195. Sensor is located in the test port as discussed earlier
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Oil Pressure Gauge Conversion Part 1 of 2 vegasmarauder Shop Talk 70 08-24-2017 05:18 PM
trans temp gauge superford3 Shop Talk 27 01-15-2009 03:06 PM
Trans temp gauge sspmustang Transmissions 2 07-02-2006 12:55 PM
Help With Trans Temp Gauge Black_Noise Community Discussion 7 03-03-2006 12:46 PM
Question about Trans Temp Gauge install Brutus Shop Talk 6 01-07-2006 06:58 PM
Powered by: vBulletin
