So I'm trying to shut my buddy up that my car has the potential to beat his and ford I superior
Any recommendations on mods to get me to his
Level currently stock Fastest 1/4 for me was 15.1
His is a 14.1
His is a 14.1
Giggle Gas
100 shot and a tune will yield you 12.5's all day long. Until you run out..
Bolt on's like a full KOOKS headers and X-pipe. Or a full stainless headers to cat back system. Gears and a good old Martyo tune. Drag radials and you can beat that Nopar AKA Mopar. Boost will make it much easier. Or NOS.
3.35 L 4X4
-AND-
SLAYER1
Can somebody provide a link to a bolt on nitrous kit I know summit racing has some but no quite sure since it's not specific to the marauder
go full boltons and sneak this on your back seat.
http://www.ebay.com/itm/COMPUCAR-NIT...-/371931472075
i had a crown vic with full boltons, higher stall and 50shot wet, 14.1-14.2 my best. sprayed right off the line
"No replacement for displacement!"
Ive beat several 6.4 Hemi with my eat swap stock Marauder Block. Do an eaton swap you'll love the car and you'll waste most of the competition on the road
I ran a 13.9 before I supercharged, so it can be done.
4.56s and a tune to go with the gears.
....then a NOS kit if you still can't beat him.
