Nice unit. How is this guy different / superior to the standard FF? Thanks.
I wanted it because of the visual indicator showing when the filter needs changing and it looks gorgeous.
Now, Injector Dynamics claims their high performance filter helps injectors work to maximum efficiency and significantly increases reliability. I do not have the experience to know if the claims are accurate or matter.
We have many, many members here who race 1/8 and 1/4 mile. I will defer to their knowledge.
http://injectordynamics.com/id-f750-fuel-filter/
"Since electronic fuel injectors are built to precise dimensions that are measured in microns, the smallest of particles can accelerate wear, or completely damage a fuel injector. The filter included in this fuel pressure regulator is highly efficient capturing a minimum efficiency of 87% at 5 microns while capturing 100% of all particles at 35 micron and larger.
Other features include a high level of contaminant while maintaining low restriction to flow. At a flow rate of 750 liters per hour, the ID750 will hold five grams of contaminant before requiring a replacement. The filter has a Delta P Indicator which provides a visual indication of the condition of the filter so that it can be serviced before needing a replacement. The filter is protected with a spin-on housing that will come with a safety latch, and it also has a pressure relief with a drain.
Included with this fuel pressure regulator is a modular mounting bracket, hardware, and a barb fitting to make it ready for installation. The fluid connection sizes are SAE -8.0 fittings, and it weighs a total of 700 grams. An optional pressure and temperature sensor can be used with this filter."
Which ID injectors are you running?
For motor break-in, Deatschwerks 39 lb/hr. Once the blower is installed, I will use Injector Dynamics or Deatschwerks (tuned down to my needs).
So...how you getting the kenne bell to pass smog?
Trilogy # 192 / T.S. 0012
Registering outside of commie-fornia?
'21 F150 XLT 5.0 Sport
'18 Chevy Malibu Redline
'10 Harley Ultra Limited
'08 Kawasaki ZX6R
'03 Grand Marquis(sold)
The car will not have plates installed, the owner's name not mentioned and there will be no mention the vehicle is intended for street use. Not a risk-free plan. Worst case, I pull the Kenne Bell and put it on my office desk at home. Then buy a Vortec, oil cooled blower from ADTR (like Lifespeed) - my original plan. But I want that liquid cooled Kenne Bell like a fat man wants a tweekie!
