Results 1 to 15 of 23
Thread: Help with Eaton Swap Please!!!!
    May 2015
    Corpus Christi, Tx
    I just installed the Eaton on my Marauder. Took it to the tuner. He got half the tune done. The car runs great until it gets to temp. Then it dies. It will restart but will not idle. He can't finish the tune on the dyno. This ever happen to anyone else? Or anyone know why this is happening?
    Thanks
    tuner does not know what he is doing. pm martyo from Mo's speed shop
    Sep 2015
    Mississippi
    I second this motion
    Jan 2015
    Mishawaka, In
    Third that, why didn't he finish the tune while there?
    What are the iat2 temps?
    Hiram, Georgia
    How much did he charge for half a tune?
    Did you leave the car with him or take it home?
    May 2015
    Corpus Christi, Tx
    $400 for what he did. Had it 6 weeks. Changed sensors and other stuff that weren't reading right. I got it back Thursday. I just went and picked it up. Drove it for bout 20 minutes and ran fine till it got up to temp then won't idle. Made 13 lbs of boost and hauled ass till it warmed up.
    If you have a stock internals motor..13 lbs. boost is a little on the high side. what are the specs of the motor? miles etc?
    May 2015
    Corpus Christi, Tx
    Stock motor other than the Eaton. It was between 10 n 13. It ran great. Until it got to temp. It will start back up just won't idle. Friend says may be the IAC
    stock motor with eaton swap are mostly in the 400-425 rwhp range and 9-11 psi. this keeps it safer for longevity, go too much and rods and pistons are short lived. i would give all your info to martyo, pulley sizes etc. and have him give you a tune. his shop has tuned hundreds of marauders from stock to 700+ hp ones and from local to canada, germany etc. my car is there right now for upgrades. a blown motor will cost $5-8k depending on labor.
    who did eaton install? cooling system was opened up for it, did you or they do the proper cooling system burp procedure to make sure all air is out? if not then you may have an air pocket causing it to get hot, but that usually happens quicker than 20 min.
    6 weeks for half a tune??? Run very far away from that clown. Call Marty.
    Jan 2015
    Mishawaka, In
    Ran hard prior to getting up to temp is bad anyway so if it's shot there are more than one reason.
    May 2015
    Corpus Christi, Tx
    Ok. Thanks for the advice. I'll get with Martyo and see what he says.
    Quote Originally Posted by krussell1203 View Post
    You'll be glad you did..Marty is all about service and that is not a M-F 9-5 thing either, He works with you sat. sun etc..to get it right.
    You may spend some money again, but Marty won't leave you high and dry.
    Wisconsin
    Good luck getting it going and have fun but you are pushing your luck real hard with boost that high on stock internals. You may want to rethink the boost level before you start another of many threads here looking for blinds/curtains for the new window in your block.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  1. What 1/4 mile ET with Eaton swap or complete cobra motor swap
    By JBeezy in forum Drag Racing Round-up
    Last Post: 04-12-2015, 07:57 PM
  2. Another Eaton Swap
    By 03sport007 in forum Power Adders
    Last Post: 05-10-2012, 12:44 PM
  3. eaton swap.
    By marauder4.6DOHC in forum Power Adders
    Last Post: 08-01-2011, 01:25 PM
  4. Eaton swap...
    By loud2004marquis in forum Power Adders
    Last Post: 05-20-2011, 06:43 PM
  5. New Eaton Swap Guy's
    By musclemerc in forum Shop Talk
    Last Post: 05-01-2010, 07:24 AM
