A week or so ago my idle speed jumped from it's nominal setting of 700 RPM (set by my tuner years ago) to 1K.
I cleaned the throttle body and IAC device, checked that the throttle blades are closed and the action is smooth. the IAC plunger is not stuck but I can't tell if the solenoid is working. However the solenoid does have electrical resistance and there is voltage at the plug.
I searched for air leaks but couldn't find any.
As I understand it the idle air is picked up by a port at the front top (interior) of the TB, between the blades. Is that correct?
Could I still have a vacumn leak? What else can I do?
Thanks,
Pat
