Results 1 to 15 of 24
Thread: HVAC damper issue
    Aug 2003
    Battle Creek, Michigan
    HVAC damper issue
    So the last time I took my car out I tried to use my AC and the air comes out at the floor, no matter what I do with the controls. Checked for EATC codes and got none.
    Safe to assume this is a bad damper actuator? Is it the one behind the radio?
    First retailed 2003 Marauder
    Bought 6 June 2002
    #168
    May still be an EATC head unit issue.
    The default setting for a loss of vacuum supply is to go to defrost. Defrost and floor share a common actuator, so there has to be vacuum pulling it to the floor position. If you put the EATC into Vent and it does not open the vent door, then it sounds like the issue may be internal to the head unit.
    Aug 2003
    I assume then that there is an air switch that puts vacuum to the actuator based on a command from the controller that could also be the issue?
    I'm slow today. Just occurred to me that if the switch is bad I would have air to the defrost.
    Bought 6 June 2002
    #168
    Aug 2003
    Looked there before I posted. My issue isn't one of the 4, but thanks for trying.
    Bought 6 June 2002
    #168
    I would check the vacuum to the head unit, start the car and pull the hose assy off the back of the eatc.
    That white hose might be ripped, or there is a also a quick connect that looks like the connection at the back of the eatc on the pass side under dash.
    Idk. I'm just trying to help
    The black hose is the vacuum supply. White is for fresh/recirc, blue is for the panel vents, and red and yellow are for the floor/defrost dual actuator.
    Quote Originally Posted by kirk View Post
    The vacuum "switch" is the plastic manifold that the solenoids attach to. When the controller commands a particular solenoid to open, it provides vacuum to the appropriate actuator.
    Aug 2003
    Further investigation leads me to believe it is the solenoid O-rings. While air is coming out on the floor, it is also coming out the defrost. I was also getting heat today that I wasn't feeling the other day. Age and symptoms indicate it's worth changing the O-rings. Probably won't happen for a month or two.
    Thanks for all the input.
    Bought 6 June 2002
    #168
    Remember to use silicone o-rings, size -007. Also check the manifold for cracks or porosity. JB Weld is your friend if you find any.
    Aug 2003
    Big help there. Thanks
    Bought 6 June 2002
    #168
    I can repair your EATC and replace the bulbs with LEDs.
    Aug 2003
    Thanks, I'll ponder that.
    Bought 6 June 2002
    #168
    Nov 2010
    Utah
    How did it go? Did you get it fixed?
    I had a very similar problem. The blend door is made of plastic with a plastic hinge. The hinge broke from normal use. Took me an entire day to fix, with hardware store bought hinges and ingenuity
    Aug 2003
    So I finally got to this today and I already have to stop and ask a question.
    The instructions state "But first, make sure they hold vacuum when not energized. Connect a hose to the center vacuum port (where the black tube was connected) and suck it. It should hold vacuum. If it doesn't, the following fix probably isn't for you."
    I have my EATC out and I did a vacuum check on the center port and it leaks.
    I thought the whole issue here is that the O rings leak and it won't hold vacuum. Is there some other seat or seal in the solenoid that should hold this or are the instructions backwards?
    Bought 6 June 2002
    #168
  1. URGENT: Harmonic damper threads stripped
    By BlueFusion in forum Shop Talk
    Last Post: 12-27-2013, 10:50 PM
  2. ac/heat damper door test??
    By lji372 in forum Community Discussion
    Last Post: 03-15-2013, 04:22 PM
  3. New guy with hvac issue?
    By drhill in forum Shop Talk
    Last Post: 12-11-2012, 11:09 AM
  4. Another Climate Control/HVAC issue
    By 69marquis conv in forum Community Discussion
    Last Post: 09-20-2006, 10:18 AM
  5. Balancer vs. damper
    By SergntMac in forum Shop Talk
    Last Post: 07-01-2005, 04:42 PM
