how many quarts my car take?
I took my car today to wallmart and they put 6 and half quarts mobile 1 5w20??
i thought my car takes only 6 quarts? is it harm to put 6 and half quarts??? :
Watch out for them duechbags. I once took my turd mobile to Batavia Walmart to get the oil changed only to get home and find my filter cross threaded and lost about half the oil. One of the few times I did not change my oil myself and it back fired. I dont trust any place. Im not sure if it will harm it but just get under it and drain a little. 6 quarts for me too
Wait at least 10 minutes after shutting off the engine, then check the dipstick. It should be a hair over the max fill line, if they really did add extra oil, and didn't just say they did.
Most likely, an extra half quart won't make any notable difference. And, it's certainly not going to cause any damage.
Whether it's 6 or 6.5, just fill it to the "full" line on the dipstick, dipstick.
Not telling you what to do but I would NEVER go to Walmart for any car services. I do however purchase my oil supplies there. Get to know your car and turn your own wrenches!
6.5 won't do anything
11.90 @ 117.5mph on 93 octane
Igziabeher
+1. Changing oil is easy. There are even equipment to make it easier. I installed one of these. No more hot plug, no more dropping said hot plug in oil drain pan.
Added this for more piece of mind.
No, it's doesn't drip.... just forgot got to wipe it off.
Also added one to the wife's Charger.
I agree change your own oil IF you have a garage. Where I live the association frowns on changing oil in the parking lot. I take mine to a private mechanic, to have the oil changed & had it done recently--he put in 6 & 1/2 quarts as the manual says---no problem. About wheel alignments--had mine done a couple of times at the dealership--still had wear on the inside. My mechanic who doesn't do alignments said to take it to PeP Boys, they use laser technology & I had it done by them 4 mos. ago & now the tires wear perfectly ! Damn who'd think that PeP Boys, would have the answer !!!!
Go to the dealer. Just buy the oil at Walmart or online or whatever, and then pay the dealer the $20 or whatever it is to change it and give you a new filter.
Igziabeher
What is that devise called for easy oil drain, and where to buy ? Thanks
