Originally Posted by
TrilogyMarauder
Its my birth month also!
And Hail Hail is a great Pearl Jam song!
You are obviously trying to stir up trouble.
Please refrain from being an immature dickhead.
Get back on your meds.
To the OP:
Sorry to hear about the hail damage.
A skilled 'Dent Doctor' tech can do some pretty amazing repairs.
