Results 1 to 9 of 9
Thread: Complete Eaton Swap!
    Pa
    Not mine, daily checking some sites and ran across this offer. There's going to be a lot of parts that are not needed I am sure of but this takes out all the hard work of going crazy searching.
    http://www.svtperformance.com/forums...age-parts.html
    somebody jump on this.
    Oct 2010
    Wow an eaton swap minus the search and hunting! not bad
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Saudi Arabia
    how much ?
    link did not work with me !
    Decent price!
    Lotsa stuff included that's not needed/usable for an Eaton swap on a Marauder, but could be re-sold to recover a portion of the cost:
    Pulley bridge bracket with tensioner and 2 idlers
    timing cover new
    timing cover bolts, studs and nuts ,(not necessary to mount Eaton SC drive system, will need gortch brackets for the MM)
    timing cover tensioner with an idler plus 2 idlers[1 smooth ,1 ribbed idler
    bolts for above tensioner and idlers (will need the tensioner and the smooth idler, but not the rest)
    Lower supercharger pulley with cage and idler
    Crank harmonic balancer new
    Idler bracket with idler - it sits where alternators sit on N/A cars
    oil cooler with adapter
    Alternator
    upper and lower alternator brackets
    Bolts for alternator and brackets
    Alternator pigtail connector
    Coolant crossover pipes with new O rings and temp sensor new (could be modifed with some work, but better off going with a modified OEM Marauder COT)
    supercharger inlet plenum with bolts and gasket
    throttle body with bolts and gasket (OEM throttle body will work)
    supercharger pulley cover
    EGR valve with bolts (can use the stock EGR valve with some minor mods, or do an EGR delete)
    EGR metal tube
    Throttle cable new (can use the stock Marauder cable with some minor mods)
    Cruise control cable new (can use the stock Marauder cable with some minor mods)
    Black bracket with emission sensors , sits on the side of Eaton SC
    power steering reservoir bracket with bolts
    Radiator hoses
    Anybody interested in an Eaton swap, this is about as close as you'll come to a "one stop shop" for the parts, and as mentioned, you can peddle the unecessary stuff to recover some of the initial cost.
    Feb 2009
    Upstate NY
    Looks to be in very good shape too.
    03 300A - Number 1727
    Oct 2011
    Westport, Ma
    Quote Originally Posted by ta3mo3 View Post
    how much ?
    3200+shipping
    Quote Originally Posted by Guittard22 View Post
    3200+shipping
    I missed his question, good catch!
    Oct 2011
    Westport, Ma
    Cheesehead
    Are you on the list that has done the Eaton swap on your ride ? Would you say it's better than the trilogy set up ? Or is the eaton set up better in the long run because part can still be found and made for it ?
    Sorry to bug you with questions and also sorry if thus sounds dumb .
    Cheesehead
    Yep, I've got an Eaton swap on my car, and, no, not a dumb question at all.
    I would say the Eaton swap is in no way better than the Trilogy, but it was definitely a lower cost alternative when Trilogys were still being offered. Now that Trilogy kits are no longer being sold, options for roots-type blowers are limited, so to a large extent, the "Eaton swap" is the only game in town. (Even if planning to install a Whipple or Kenne Bell, you've got to use some of the Cobra Eaton parts as a basis).
    Actually, both the Cobra Eaton and the Trilogy blower head are M112s, but the Trilogy set up uses a different plenum design that allows driver's side air intake, which makes it a direct replacement for a NA set up. The Cobra Eaton is passenger side intake, which requires relocating the battery and some other peripheral components in the engine bay.
    Also, the Trilogy was a complete kit, everything needed to convert from NA to S/C was included in the box, ready to bolt on; whereas the Eaton swap requires you to round up the used OEM Cobra parts, new OEM parts from Ford (if used ones can't be obtained), and aftermarket parts (such as the gortch brackets) as well as fabricate various other brackets and such. I found that part of the project to be a lot of fun, but for some folks, parts chasing is a PITA.
    If they still offered Trilogys, and if I could afford one, I'd buy one in a heartbeat. That said, I love my Eaton swap, and don't regret going that route.
    Bottom line: Whatever FI system is chosen, Can't Beat Boost!
  1. For Sale Eaton kit. Almost a complete kit. $1800
    By guccijayda in forum Marauder-specific Parts for Sale
    Last Post: 12-01-2010, 10:09 AM
  2. Eaton swap in MN yet?
    By marauder4.6DOHC in forum Twin City Marauders
    Last Post: 11-22-2010, 12:33 PM
  3. For Sale Complete Eaton Swap
    By Zack in forum Marauder-specific Parts for Sale
    Last Post: 08-19-2010, 05:52 AM
  4. For Sale Complete Eaton Swap
    By tjl006 in forum Marauder-specific Parts for Sale
    Last Post: 06-29-2010, 07:20 AM
  5. Eaton Swap #11
    By SmokdMercRauder in forum Power Adders
    Last Post: 05-10-2010, 04:50 PM
