Complete Cobra Everything Swap
Originally Posted by
REVINKEVIN
So, I was wondering if anyone has done the complete Cobra engine transmission swap on a Marauder.
You tell me? Not exactly a Termi trans, better, a 2012 GT 500 TR6060 with twin disc.
Before you even contemplate the thought of a swap its best that you own some basic hand tools like this. Or a beautiful wife who buys them for you.. 😜
Now for some pics, mind you I only started last week and nothing you will see is finished thanks to my daytime plumbing gig and snow plowing.
OEM shifter.
Marauder converted.
Tunnel is now cut much more. 5" X 14" IIRC for the shifter to mount under the car like its suppose to.
Shifter boot. No trimming on the counsel needed. Only minor trimming of the plastic frame under the boot itself.
This trans not only requires a new trans tunnel but set at the exact tail shaft height, the mount is at the same elevation as the old cross member. Could I find a way to "make" it work? Sure, but that isn't my style.
*not finished, just 90% and mostly just squared up and tacked."
I doubt I will be able to finish this and may have to go back to the auto to make the Louisville meet because of other commitments that start up in two weeks, because I am also dropping in my Termi block and cams. But I am gonna give it hell!
Oh BTW, mechanical clutch pedals are for the hacks. 😊 Go hydraulic! 😜
Also keep this between you, me and the Internet please. I don't want this to get out yet,
Complimentary booby pic included.
Sent from my iPhone 4s using Tapatalk
