Started this morning after driving approx. 5 miles. Aftermarket locking cap on as snug as ever. Riding around on teeth jarring washboard roads recently. Any thoughts?
Current Garage:
2005 Mustang GT Premium
2015 Triumph Trophy SE
― William W. Purkey
I have had this issue on different cars with aftermarket locking caps. Sometimes you have to just take it off and put it back on again. See if that works.
I think you can use your sct programmer to resent the light. Then see if it returns.
Probably the cap. Use the original cap unless there is a problem with gas theft in your area.
Reset fuel cap - no change. 'Check Engine' lamp came on this afternoon, followed by periodic 'erratic idle' - no stalls, but close. Left at local repair shop here in SC - reputable and appears to be well equipped. Service Writer - Dispatcher had never heard of a 'Mercury Marauder'(?!?!) but was impressed otherwise. Shop was advised: 'Do NOT reflash ECM'. Know something tomorrow. Won't be home until early next week at the soonest.
Current Garage:
― William W. Purkey
Picked up car: Canister Purge Solenoid replaced. Running well again with a steady, semi smooth idle (good). Before the last malfunction, the car would alternate between a 'nervous' idle (lean trim) and the normal 'semi smooth' idle. I'm happy again.
Current Garage:
― William W. Purkey
OK, I'm asking for a reason...was it the Canister Vent Solenoid or the Canister Purge Valve? (they are 2 different things...one's in the engine compartment and the other's in that tray under the trunk)
Current Garage:
― William W. Purkey
I'm having an EVAP issue with my 2004 Grand Marquis and was hoping they would be more accurate in describing which piece they replaced...oh well.
Shop is closed weekends. I will contact them monday and report back. Judging by what I was charged, the 'purge valve' was changed out - heck of a markup too. I'll find out for sure monday. Motorcraft device depicted.
https://www.carid.com/motorcraft/vap...7&url=12770410
Current Garage:
― William W. Purkey
Yup, that's the Purge Valve...lives on the firewall, passenger side. Ford officially calls it the Vapor Management Valve, but yeah...that's not the Canister Vent Solenoid.
Thanks for clarifying.
Subscribing................... .......ds;ofda,kzdfzvnli n c fmjz sru,g
Current Garage:
― William W. Purkey
This is from the 2004 OBD System Operation Manual from Ford:
"First, the Canister Vent Solenoid is closed to seal the entire evap system, then the VMV is opened to pull a 8" H2O vacuum. If the initial vacuum could not be achieved, a large system leak is indicated (P0455). This could be caused by a fuel cap that was not installed properly, a large hole, an overfilled fuel tank, disconnected/kinked vapor lines, a Canister Vent Solenoid that is stuck open, a VMV that is stuck closed, or a disconnected/blocked vapor line between the VMV and the FTPT."
P0455 is what I'm getting.
Current Garage:
― William W. Purkey
