Results 1 to 6 of 6
Thread: After the search feature ... I still have a question or two
    Nov 2007
    Pleasant Hill, CA
    Okay,
    The search button is your friend and provided me some answers.
    I know the difference between a 300A and a 300B and I even read about the transition models. These seems to be fairly reliable motors. The aftermarket looks respectable. Parts don't seem to expensive (I come from the Taurus SHO market).
    So, here is the first question(s) from a newbie ... and I don't even own one yet ...
    Do I need to find a special mechanic to work on these or will most shops charge me more to work on it because it is a Marauder?
    How hard is it work on these motors? I done some on my SHO.
    These two should be enough to start.
    Thanks!
    Anthony
    Jan 2006
    Central Ohio
    Hiya, and Welcome!
    Any GOOD Mustang Tech should be able to work on the Marauder, imo. Yes, there are a few differences, but it is the same concept.
    Any yes, you should be able to do quite a few things yourself if you have the skills.
    KillJoy
    Aug 2005
    Charlotte
    Any Mustang or Ford shop should be able to work on it without a problem. If they say they need to charge a premium because it's a Marauder I would try to find out if they are charging that because something is expensive as a 4v part or they are trying to just get money out of you.
    Our motor is not really that rare. Between the Mach 1 and Marauder there are 27,886 cars out there. Of course there intake goes the other way but for the most part it's the same. Also don't forget that the Lincoln Aviators 03-05 had the same motor as well. So there are probably well over 50k cars with this motor. I did not count the 99 and 01 cobra since they use different heads and other parts and may not have some of the issues that the 03+ n/a 4 valve motors had.
    The only time you may want someone who to work on the car that has experience with Marauders is with tunning but I would be willing to be that a good reputable Mustang shop cand tune it just fine.
    2003 300A
    Black Marauder with Tints
    K&N Intake, Accufab TB, VRS catted mid pipe, SCT SF Tune, PHP Control Arms. Sold in 2014, totaled out in 2015
    1994 Mustang GT
    Red Convertible
    1/2 Vampire, prefers to stay in a garage as opposed to seeing light.
    Quote Originally Posted by 94_302 View Post
    Bravo!
    Nice summary.
    2017 Niro
    Longwood, FL
    You'll love the Marauder. You'll _ _ _ on yourself if you start out buying this one:
    http://www.mercurymarauder.net/forum...ad.php?t=39617
    (meant as a compliment - wish I could afford to own two MM's)
    2003 300B
    VIN: 677166, #6738 of 7839
    built: 2/13/03
    wrty start: 5/28/03
    84,197 on 02/21/08
    95,776 on 02/21/09
    109,301 on 02/21/10
    121,447 on 02/21/11
    125,925 on 02/26/12
    130,375 on 01/01/13
    134,831 on 2/4/14
    149,441 on 2/24/18
    Dark Blue Pearl, #128 of 327
    Nov 2007
    Pleasant Hill, CA
    Quote Originally Posted by Paul View Post
    If I were to buy one today, I would need to look at Hack's. However, I am not buying quite yet, this is my research time. I need to find out the pro's and cons of these beasts before I committ to buying one.
    Anthony
  1. LEO Question - Firearm Defense
    By Dan in forum The Lounge
    Last Post: 03-23-2006, 07:56 PM
  2. Spark plug heat range question
    By Todd in forum Community Discussion
    Last Post: 11-21-2005, 11:32 AM
  3. Exhaust thoughts and Magnaflow question
    Last Post: 11-07-2005, 11:12 AM
  4. Brake kit question
    By Todd in forum Steering, Suspension & Brakes
    Last Post: 04-15-2005, 09:47 AM
