Results 1 to 6 of 6
Thread: Rough idle wont go away
    Jan 2009
    detroit
    My car idles at 5000 rpms while in drive with my foot on the break and its kinda rough and putters when I let off it right away also when I'm in reverse it idles really low. I cleaned the maf, iac, tb, ran the sea foam through the pcv valve, and put double platinum plugs in and its still hasnt helped it what could be the problem
    Jan 2008
    Colorado
    5000 rpms???
    Did you fix the broken bolts? Does it still have the high pitch whistling noise?
    Is there a active code now?
    BAIR
    Jan 2009
    detroit
    Quote Originally Posted by imorb1994 View Post
    5000 rpms???
    Sorry 500 rpms and yes I fixed the broken bolts no more whistle and this actually started happening after I emptied the first set of cats and removed the 2nd set could it have anything to do with that?
    Jan 2008
    Orlando, FL
    Essentially removing your cats will remove back pressure and alter the engines running characteristics.
    Does the idle smooth out if you tap the gas a little and raise it to like 800rpms?
    I would get a XCal and a tune... and raise the until until you are satisfied. I set mine at 850 in gear.
    -2003 Mercury Marauder 300a-
    Mar 2006
    holy city
    Quote Originally Posted by james1986fox View Post
    This is just a wild guess!!!
    if you read your post there in may be your answer
    Aug 2008
    Marauderville MD
    2004 DTR Mercury Marauder
    Build date:8/18/03
    Delivery date:8/14/08
    #21 of #983 DTR's
    #51 of #3213 in 04'
    And im not spanish my friends just say i look it the names "Michael"
    Quote Originally Posted by DTRMiguel View Post
    Fat people dont get kidnapped
    Zack Tune
    JLT DTR Cold Air Intake
    1/4 Mile ET 14.202
    1/4 Mile MPH 99.13
  1. Rough at idle
    By mtenderenda in forum Shop Talk
    Last Post: 07-16-2008, 05:05 PM
  2. Rough / Low Idle
    By arejayesss in forum Shop Talk
    Last Post: 09-26-2007, 05:54 AM
  3. Rough cold engine idle
    Last Post: 05-09-2004, 02:35 AM
  4. Missing and rough idle
    By Festus in forum Shop Talk
    Last Post: 10-08-2003, 08:17 PM
  5. Shifter Problem & rough idle / hesitation
    By capt512 in forum Community Discussion
    Last Post: 07-09-2003, 09:26 AM
