MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 10-16-2016, 08:38 PM
Mrauder83's Avatar
Mrauder83 Mrauder83 is offline
Senior Member
Trader: (1)
Heat coming from the top and bottom of dashboard with no air or heat on.
The car has 197k on it, motor was replaced at 173k about 2 1/2 years ago. Blend motor needs to changed and I and I think the blower motor might of went out as well. Now when I'm driving for about 10 minutes the cabin gets hot, I can feel hot air coming from the top and bottom vents of the dash. Any idea of what could be causing it?? Could it be the transmission getting to hot, because I also noticed today that when I went WOT the RPMs went up it hesitated then went into gear. Transmission feels like its starting slip going about 35-40 mph. Only work done to transmission was the JMOD and that was in 2012. I know that's a lot but could the transmission be on its way out which it's getting too hot which is causing the heat to come thru dash when no air or heat is on.
  #2
Old 10-16-2016, 08:47 PM
Cabotwick Cabotwick is offline
Member
Trader: (0)
My transmission was rebuilt 9 months ago. I have that weird heat thing too. Heat isn't on, but it's got as **** in the car lol. I just crack the sunroof😏
Sent from my Z981 using Tapatalk
  #3
Old 10-16-2016, 08:50 PM
Mrauder83's Avatar
Senior Member
Trader: (1)
How long has that been happening? Me myself I've never had that issue with the heat until about June or July of this year.
  #4
Old 10-16-2016, 08:52 PM
Member
Trader: (0)
Almost 2 years. I had the heads done, replaced that stupid aluminum tube with a hose, and I've had it pressure threaded 4 times because it continued to overheat until i bled it like 5 times. But the heat is still there. Maybe because the air blend door is stuck, the great constantly flows... I dunno
  #5
Old 10-17-2016, 03:35 AM
Mrauder83's Avatar
Senior Member
Trader: (1)
Oh ok. I dunno myself I'm thinking it's because of the blend door but that has been acting crazy for about a year. The heat issue just started.
  #6
Old 10-17-2016, 04:44 AM
fastblackmerc's Avatar
Trader: (75)
Did you run the EATC self-test?
Run it and report back the code(s) you get.
The hot water is constantly flowing through the heater core. The blend door regulates the amount of hot & cold piped into the cabin.
I bet your EATC needs to be rebuilt also.
__________________
  #7
Old 10-17-2016, 04:53 AM
Mrauder83's Avatar
Senior Member
Trader: (1)
Ok, I'll do the test when I get off this evening. Thanks for the info that's new to me never had this issues before. What does the rebuild consist of?
  #8
Old 10-17-2016, 11:54 AM
Mrauder83's Avatar
Senior Member
Trader: (1)
Error code was 024
  #9
Old 10-18-2016, 04:49 AM
Trader: (75)
Error code was 024
024 = the blend door actuator is bad.
Part - about $75.00
Labor - 3-4 hours
__________________
  #10
Old 10-18-2016, 04:50 AM
Trader: (75)
Replacing the o-rings. I also upgrade the button & fan wheel lights to LEDs.
__________________
  #11
Old 10-18-2016, 05:11 AM
Mrauder83's Avatar
Senior Member
Trader: (1)
Ok so I can just send you the whole unit?
  #12
Old 10-18-2016, 07:05 AM
Trader: (75)
Yes, PM me for the details.
__________________
  #13
Old 10-18-2016, 07:17 AM
Mrauder83's Avatar
Senior Member
Trader: (1)
Ok
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: vBulletin
