I am in trouble. I was in a hurry to change my radiator fluid today before dinner with my family and I broke the draincock. Yes, it is made out of plastic but the fault lays only with me. After all of the fluid drained I hand tightened the draincock and then used my socket wrench and socket for one last turn in hopes of fully tightening it. To make a long story short, I heard a crack and when I removed the socket the head of the draincock came out with it.
Lucky for me, I was able to stick an alien key inside of what remained of the drain **** and lossen it so that it is not stuck inside. To my surprise and horror I noticed that the drain **** does not fully come out. No matter how much I turn and turn the remains of the draincock fails to fully remove. It is almost as if it is not designed to be fully removed.
This is what scares me the most. What are my options? Can I buy just one little drain **** from the dealer?
If yes, how do I remove the remains of the broken driancock? Should I just attempt to brake it off in order to remove it? I am afraid that a small piece might get into the cooling system and brake a pump or what not.
Anyways, I know that I am the only one here who can make such a ____ mistake but the only thing keeping me from going crazy is that I know that many of you are going to head me into the right direction so that a bad day could be over as soon as possible.
Best
