Results 1 to 15 of 27
Thread: Engine Install This Week!
    Finished all the little details on the engine, it's ready. Gotta do a little bit of work on the car before it goes in, so maybe late tomorrow or sometime the next day it'll be installed.
    Here's the fittings and wiring for the oil pressure sensor and warning light switch:
    A closer shot, ps pump and sensor removed:
    And here with the sensors installed:
    Something else new, a flexplate shield:
    Another view, see the sfi sticker:
    Other side, look close and you'll see the modified mounting bracket for the dipstick tube:
    Unfortunately it didn't clear the header, glad I bolted it all together before engine install. BFH fixed it, but violated sfi certification by modifying:
    Starter heat shield:
    and slightly rerouted tranny lines:
    Here's the whole thing:
    Other side:
    Blog Entries
    2
    Looks awesome. Good luck.
    Where does your remote OF mount?
    Did you ever have a chance to break down the old engine for an anal?
    Mounted on the frame, just barely clears the sway bar but it's tucked in there nice and safe while being readily accessible for service.
    Haven't had time to mess with the broken engine.
    Washington DC
    I am excited about this one.
    Merc's Garage
    Oct 2005
    Sparkling Clearwater, FL
    I can't wait to see that thing plugged in! Doesn't somebody make an oil accumulator, maybe Moroso, that precharges your engine oil pressure each time you start it up? Since you're going remote, that might be a wise addition. And yes, I know it's easy for me to spend your money!
    J
    Alex, you'll always be with us!
    '04 Crown Victoria LX Sport 230A
    Bone Stock (Really, would I lie?)
    I couldn't see destroying a Marauder as my daily driver!
    '03 Marauder 300B as in blue
    DOB 5/12/03 - adopted12/01/06
    1 of 328
    SS Inserts
    Quote Originally Posted by JMan View Post
    J
    Yeah, I've been thinking about that but I can't figure out a spot to mount it. Check with Scott & Jason at Team Ford, they dread seeing me come in any more because there is so much "stuff" mounted in the engine bay you have to disassemble something for access to anything.
    Oct 2005
    I think you'd mount it with the remote filter assy. Where are you putting it? Left front inner fender? That would have some extra space, I'd think.
    Keep on truckin'
    J
    1 of 328
    SS Inserts
    Keep on truckin'
    J
    It's on the inside of the frame rail under the air filter, been there a couple of years. No extra space there due to pipes between supercharger, intercooler, and throttle body. Both front fenderwells are filled up (water injection, auxiliary tranny cooler, brake cooling ducts) as well as the fenderwell recess at the shock/control arm (PCV trap). I'll study it some more once the engine is back in.
    Good luck Brian.It looks ready.
    sleeper
    Aug 2005
    JUPITER
    Damn!!!!!!!!!!! Way to go Brian!!!!
    2003 300A Black MM
    Ride it like a Ford.!!
    All I want to know is how much LESS money you spent than Marty!
    Dec 2004
    Arizona Territory
    Missing a nut on the driver's side header... second tube !
    Nice looking engine !
    AzMarauder
    Sierra Vista, Arizona
    2003 Marauder 300A
    Black
    Trilogy Supercharger Serial # 105
    Installed 9/30/2005 - 10/6/2005
    2010 Dodge Challenger R/T
    Detonator Yellow
    1967 Ford Fairlane, 428CJ, 5spd, running dual quads.
    Brian, do not put an EGR on that thing, PLEASE!!!!!
    Oct 2003
    Afhaggisland
    J
    Check with Joe Walsh, he has one on his Marauder.
    Saorsa gu Brath
    (Freedon Forever)
    Si vis pacem para bellum
    Μολὼν λαβέ
    (Come and take them)
    Stann saam of sterf allen
    (Stand together or die alone)
    Audentis Fortuna Iuvat
    (Fortune Favors the Brave)
    "THE BLACK BOMBER"
  1. Z&M Control Arm Install Detail.....DUW!!!
    By MM2004 in forum Steering, Suspension & Brakes
    Last Post: 08-13-2007, 10:53 AM
  2. New Engine, No Warranty
    By Ross in forum Shop Talk
    Last Post: 03-02-2006, 06:29 PM
  3. About a Trilogy Kit & Carfixer Install
    By Smokie in forum Power Adders
    Last Post: 02-25-2006, 06:14 PM
  4. This may not be popular(concerns fuel flow)
    Last Post: 01-22-2006, 04:15 AM
  5. Power Stroke Diesel Owners,....
    By MM2004 in forum The Lounge
    Last Post: 12-14-2005, 09:01 PM
