Results 1 to 9 of 9
Thread: Parking brake?
    May 2004
    Normally Ga.
    Question Parking brake?
    OK, is it an "E" brake or a "parking" brake? I've always known it as a parking brake because that's what normally set before you get out of your car. Long time of driving a stick shift here. Unless you want it to roll into a Honda or something else. Petro!
    My understanding because I've tried it, that it doesn't do well in emergences, try it yourself when it really matters. I was taught that it was made so pressure would be taken off the gears in stick cars or parking tooth in auto trannys so nothing would break and the car would not roll... where, anywhere. normally
    So what gives? Is it an "E" or a "P"?
    Now, before you jump, go back to an earlier time where everything was a stick shift. If you didn't have it in gear you set the "PARKING BRAKE". Those were the most of the cars I've ever owned. I can get into detail but I decided not too. Thanks everyone.
    Sorry guys, this was part of a vent for me. No more soap box.
    Definition: Parking brake: The mechanical hand- or foot-operated brake that prevents the vehicle from rolling or slipping when parked. (stationary)
    Look up "E" brake.
    2003A Mercury Marauder. Sold it, miss it.
    USMC 06-10-96 to 06-21-06. AH-1W and UH-1N!!!! OORAH!!
    Apr 2005
    Queens NY
    Quote Originally Posted by torinodan
    Look up "E" brake.
    I can remember back to my parents chevy that had the words "Emergency Brake" on the Pull release handle on the lower left hand side of the dash. I agree with you that it should be called the parking brake However, If you lost all your brake fluid because of a broken brake line or if the master cylinder took a crap, The "Emergency Brake" is mechanical and it could very well be used to stop the car should the Hydraulic Brake system fail. Or in Other Words, A Emergency! lol
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    well,.. I'll use the Parking brake when working on the MM for now on,... unless it's an emergency,.. then I'll use the 'E' Brake!!
    Aug 2004
    Maryland
    I use it all the time when parking.
    11.98 @ 115 mph
    Quote Originally Posted by Defyant
    Absolutely!
    If you rarely, or worse, never use it, chances are that when you do try to use it the cables will be rusty.
    You'll end up with the parking brake stuck partially 'on' and smoke the brake pads.
    (In the case of our Marauders, there is a seperate small drum brake assembly in the center of the rear disc brake 'hat'.)
    Just ask my girlfriend.....I used her parking brake when I drove her car and it stuck 'on' because she hardly ever used her parking brake.
    BTW: I love cars with hand pull parking brakes because they are much easier to use when you want to bleed off speed without activating your brake lights....
    May 2004
    Venice, Florida
    What if it's a "parking emergency"?
    Then what?
    Huh?
    2003 Marauder 300A
    Tallboy's Garage
    And why pray-tell would you want to do that?
    Aug 2004
    Maryland
    Quote Originally Posted by Tallboy
    Then what?
    Huh?
    Thats when the the parking break becomes the emrgency break. You must remember to engage the hazard lights too.
    11.98 @ 115 mph
    May 2004
    Normally Ga.
    Then what?
    Huh?
    Is this when your sliding into a parking spot a Wal-Mart trying to beat someone else?
  1. TCE brake kits REVISTED
    By Todd TCE in forum TCE Performance
    Last Post: 02-13-2005, 12:18 PM
  2. Creaking from the rear : parking brake
    By TripleTransAm in forum Shop Talk
    Last Post: 01-14-2005, 01:20 PM
  3. parking brake release during reverse
    By joflewbyu2 in forum Community Discussion
    Last Post: 01-14-2005, 01:48 AM
  4. parking brake
    By nexstar7 in forum Shop Talk
    Last Post: 03-07-2003, 07:42 PM
