I saw this Marauder at a junkyard yesterday. Yes I grabbed one good part left.
Also, I broke a winter wheel last night and someone turned it into a meme already.
What a month...
What a month...
"Bye Bye, Johnny B. Goode."
At least you found one in a junkyard... Too bad there wasn't anymore to salvage.
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15
SOLD
Is that at Victory Auto Wreckers?
Buying things I don't need, with money I don't have, to impress people I don't know!!!
Production #1489 of 3213/#516 of 997
I stripped about 90% of that car, got there the afternoon it was set only things missing at the time were the console gauges/pod and the rear spoiler.
2007 DTR crown Vic lx sport 118k miles
Mods - marauder spoiler and gauge pod, dot matrix shifter bezel, trunk organizer, 6cd audiophile radio and subwoofer, headlight relay harness, p71 fascia and taillights, 18" gt500 wheels, blue silicone hoses, Stainless works headers and catback, metco control arms, addco sway bars, and steeda underdrives.
U pull it on north ave
Vin: 2MEHM75V63X615175
Build Date: 6/10/2002
Serial#: 995 of 7839
995 of 7093 Black
Accel coil on plugs/Autolite 104s/ K&N intake/Flowmaster 40s/Powdercoated goodys/
LED Grille scanner/BIGCARSFOREVER Dead pedal/SCT Tune/BBK Power Plus twin blade 65mm throttle body
I got there a a day later interior was gone some Facebook crown vic guys beat me to it but I pick the visors , lower and upper manifold , and a BBK Throttle body , door lock actuators , pcv tubing , purge valve with tubing and vacuum lines
Sent from my SAMSUNG-SGH-I717 using Tapatalk
995 of 7093 Black
995 of 7093 Black
995 of 7093 Black
If the stainless door trim isn't all bubbled up underneath, should have taken it, and if you can get anymore window trim off..
I took a door trim also the other were bubbled
995 of 7093 Black
Car had lots of good stuff I got:
Rear bumper
Exhaust tips
Seats
Unbroken console parts
Dash trim
Subwoofer
Taillights and rear fascia
Door handles
Side mouldings
Door panels
Gauge cluster
Headlight switch
Remains of the k&n intake
I see the front cover is broken
Is the shortblock good? Heads good?
If that was in my junk yard I'd pick that motor out, parting out all the small Engine pieces would pay for spare heads and a short block
Nice find guys!
