MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Transmissions
Transmissions This forum is to exchange information about the 4R70W & 4R75W transmissions.
Reply
Thread Tools Display Modes
  #1
Old 03-05-2010, 08:31 AM
babbage's Avatar
babbage babbage is offline
Super Touring
Trader: (11)
Lightbulb Just bought a new trans cooler - mounting questions
Tru-Cool MAX transmission cooler (Mini Max): Bulkpart transmission parts
Here is what I bought. It is a size smaller than what Darren (Bc-Automitive) recommended, but I think it will be fine. I wanted to mount it low in the car behind the lower slit in the grill in between the fog lights - so it will get fresh air. Any tips on this job? Anyone done it?
I was going to put it INLINE after the stock cooler with the thermal bypass before it.Also the lines on this are 3/8 and the MM uses 5/16 what's the best way to deal with that? Thanks
3/8" hose barbs on side of cooler.
Size 4 x 23 x 3/4 inch
WITHOUT external thermal bypass! ( I purchased one)
8 plates, 24,000 GVW / 22,000 BTU ratings
I've been running with just a deep pan and no cooler with my 9.5" PI. I need to get my SGII upgraded so it will read the trans temp.
Suggestions and comments welcome. I did read every post in this forum related to a cooler...
__________________
03 300A - Number 1727 - 13.8@99 N/A - Mods list - Garage
  #2
Old 03-05-2010, 08:38 AM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (40)
Make some brackets out of aluminum stock and buy the correct brass 3/8 to 5/16 adapter fittings.
  #3
Old 03-05-2010, 08:54 AM
babbage's Avatar
Super Touring
Trader: (11)
Quote:
Looking at what I have - what would you buy for fittings- Are those hardware store type items?
What do you think about my proposed mounting location?
Tanks!
__________________
  #4
Old 03-05-2010, 08:56 AM
Black bart's Avatar
Black bart Black bart is offline
Senior Member
Trader: (0)
Trans Cooler
I mounted (sheet metal screws) mine on the sheet metal bracket just behind the front grill and in front of the lower portion of the radiator.
Itís a bit of a pain to drill the sheet metal screws pilot hole but it can be done with care.
Routing the hoses takes a little care to safe guard against chaffing the hoses. I used rubber grommets to insulate the hoses from chaffing.
Take your time.
As suggested source the correct fitting hardware
__________________
2003, 300A - 76K Miles, Lidio Tune, Steeda UDP, Stewart WP, 180 T-Stat., Flat Plate Trans Oil Cooler, 4:10 Gears, Auto Meter Oil Pressure & Volt Meters, Heinous Motorsport CA, K & N Air Filter, 31 Spline set-up, Red Brake Calipers
  #5
Old 03-05-2010, 01:35 PM
babbage's Avatar
Super Touring
Trader: (11)
Take your time.
I guess I'll wait for the kit to arrive as it looks like there are step down fittings to 5/8 included. Got any pictures?
__________________
  #6
Old 03-05-2010, 01:37 PM
LeoVampire's Avatar
LeoVampire LeoVampire is offline
Senior Member
Trader: (3)
just a question
Quote:
Why didn't you get one with a thermostat and a cooling fan?
I have seen these on Summit Racing and have seriously thought about one of those.
__________________
Assembled 12/17/2003
#1183 of a build of 3214
and is #379 of 1237
Link to Mod's and car:
  #7
Old 03-05-2010, 01:59 PM
babbage's Avatar
Super Touring
Trader: (11)
This is the brand and style Darren said were the best. The BTU rating says a lot. I wanted this one as it looked like it would fit "perfectly" in the lower bumper area opening - you know the one with nothing in it now. Plenty of fresh air. I don't think you need a fan if the cooler is good enough.
What do you have on yours? Anyone got pictures of a wide but short cooler mounted below the radiator?
__________________
  #8
Old 03-05-2010, 02:02 PM
LeoVampire's Avatar
Senior Member
Trader: (3)
Just have the stock set up on mine!
I would just be worried about running it lower with rock's kicking up and what not.
Did you add that gutter mesh to the open area of the front Bumper cover your talking about to help protect it?
I am finaly adding the deep tranny pan this year to help with possable heat problems with the tranny.
__________________
and is #379 of 1237
  #9
Old 03-05-2010, 02:54 PM
babbage's Avatar
Super Touring
Trader: (11)
I'm not worried about rocks. I will immediately pass anyone that is throwing stones or back off in a hurry. I don't like it when my car gets stoned...
__________________
  #10
Old 03-07-2010, 06:56 PM
babbage's Avatar
Super Touring
Trader: (11)
I'm not good a fabricating - so I'm going to a friends shop, he has stainless flat stock.
I think I want to hang (2) bars down from the top of the radiator support and then bolt the cooler to that. Good idea or bad idea?
__________________
  #11
Old 03-07-2010, 07:08 PM
tjl006 tjl006 is offline
Senior Member
Trader: (7)
Sounds good thats how I did mine. I Made brackets out of aluminum from the top of radiator support and then just ziptied bottom of cooler to plastic chanel in front of radiator.
  #12
Old 03-07-2010, 07:17 PM
babbage's Avatar
Super Touring
Trader: (11)
Quote:
So no "L" shape at the top? Just drill holes in each piece. Zip ties keep it from swaying back/forth?
Thanks.
got any pictures?
__________________
  #13
Old 03-07-2010, 07:27 PM
Senior Member
Trader: (7)
Yeah got pictures give me a minute.
  #14
Old 03-07-2010, 07:36 PM
Senior Member
Trader: (7)
Brackets are an L shape, bolted to top of cooler. then bottom is zipties to that plastic wire chanel in front of the radiator to kepp it from flopping around.
  #15
Old 03-07-2010, 07:37 PM
Senior Member
Trader: (7)
I had to make anew horn bracket to move it closer to the radiator.
Reply
Tags
transmission cooler
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
For Sale Trans Cooler FS FordNut Marauder-specific Parts for Sale 7 01-02-2010 07:34 AM
Finally bought my own tire mounting machine and balancer for home use Stranger in the Black Sedan The Lounge 19 04-21-2009 08:01 PM
Trans cooler Jolly Roger Transmissions 3 01-16-2009 06:31 PM
Trans Cooler DTRMiguel Transmissions 14 01-13-2009 06:41 PM
trans cooler lucenti Transmissions 1 10-30-2008 05:05 AM
Powered by: vBulletin
