Results 1 to 15 of 15
Thread: SW Headers (lead pipes question)
    Feb 2014
    Palm Beach
    I'm about to purchase the Stainless Works headers for my 2003. I'm wondering if I need to purchase the set up that includes the lead pipes or just the headers. I don't need the catted ones so if I need the leads it will be the off road ones. Basically, what would be the reason to purchase the set up with the leads.
    If it matters, my exhaust is all stock now but will ultimately consist of the headers, rear cat delete, (probably AT2525s), and res delete tips.
    Thank you for the help.
    Oct 2010
    The lead pipes are what will connect your headers to your stock exhaust , so yes you need them , or have a muffler shop fab some pipes.
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    I'm doing the same thing very soon. I already got rid of one set of cats and I have the delete tips.
    18psi pulley
    Billet Oil Pump
    ARP Bolts and head studs
    Snow Methanol Injection
    3500 Stall Converter (PI)
    Stryker 340 Fuel Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Apr 2011
    Statesville, NC
    Quote Originally Posted by PB Marauder View Post
    I hope you like it loud, because thats what you will get!
    I have stock manifolds, rear cat delete, AT2525s and 4" Res delete tips, at certain rpms and speeds there is a very noticeable drone, will be switching to the AT2525XL's shortly to hopefully lower the tone and get rid of some dorne.
    Oct 2010
    Quote Originally Posted by jwibbity View Post
    Your kidding right i have a full stainless works header/exhaust system , its nowhere nearly as loud or obnoxious as Aeros!
    ITS ALIVE !!!!!!!!
    Apr 2011
    Statesville, NC
    Quote Originally Posted by MOTOWN View Post
    the OP stated SW headers and "probably" aero AT2525 mufflers which will give him a pretty loud exhaust
    Hiram, Georgia
    You need the lead pipes.
    Incidentally, I am a SW dealer and can probably offer you better pricing than you will get anywhere.
    Let me know if I can help you.
    Oct 2010
    Your right! didnt catch the Aero part! that will make for a loud and raspy exhaust!
    ITS ALIVE !!!!!!!!
    Apr 2011
    Statesville, NC
    thats why I will be changing to the XL versions, built in resonator and the mufflers I believe are 26" long, that should quiet it down alot!
    Feb 2014
    Palm Beach
    I read on here that extending the tips out from the bumper about an inch will reduce interior drone ?
    Hiram, Georgia
    It will definitely help reduce the drone.
    Jun 2007
    Whitehall, PA
    I just read that ultimately you want to have a rear cat delete, if you purchased the off road SW headers you will have no cats on the car whatsoever and your current cats are too small in diameter to properly fit(choke point) in the lead pipes. You will need custom work to make them fit. My advice would be to just buy the catted system.
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    Feb 2014
    Palm Beach
    Would it be less expensive to buy the catted system than to have the custom work done? In your opinion?
    Hiram, Georgia
    Depends on your access to someone who can work with stainless and do as neat a job as Stainless Works. I would say by the lead pipes for a quicker, neater, more efficient install. Sometimes saving money is not the only factor to be looked at.
    Feb 2014
    Palm Beach
    Ok good advice. Thank you for the help!
  1. quick question about headers
    By bigmerc281 in forum Exhaust
    Last Post: 03-18-2014, 06:50 PM
  2. Question for you guys with headers...
    By Blackened300a in forum Exhaust
    Last Post: 08-05-2011, 08:07 PM
  3. question about long tube headers??
    By Youngblood in forum Exhaust
    Last Post: 10-07-2010, 06:07 PM
  4. Redundant Smoke from tail pipes Question
    By NOMARQUIS in forum Shop Talk
    Last Post: 05-11-2009, 07:24 PM
  5. Are crown vic mid pipes bigger than the 2" Marauder mid pipes?
    By Stranger in the Black Sedan in forum Exhaust
    Last Post: 04-04-2008, 11:43 AM
