Results 1 to 15 of 19
Thread: Body side mouldings
    May 2003
    Wichita Kansas
    Body side mouldings
    Any one have a good source for the door mouldings. Mine are peeling and need repainted so planned to purchase replacements and have them painted
    Joe
    2004 SB
    4.10's and a tune
    More to come
    Oct 2003
    Beaufort, SC
    Sand and repaint the ones you have......not a bad job!!
    obsolete item from ford, no known aftermarket matching ones. refurbish yours unless one of these cars being parted out has them avsil. to repaint
    Timbuk3, MI
    Exclamation
    RubberCtyRauder - obsolete item from ford ...
    Still available (as per parts.ford.com) ...
    • Fender
      5W7Z-16036-APTM - RH
      5W7Z-16037-APTM - LH
    • Door (front)
      5W7Z-5420878-APTM - RH
      5W7Z-5420879-APTM - LH
    • Door (rear)
      5W7Z-5425556-APTM - RH
      5W7Z-5425557-APTM - LH *Currently on back-order
    NOTE: All are Paint To Match.
    Also, can substantiate that at least the LH front fender trim was available as of Sep'2017 - had need to buy one.
    alot of those part's websites do not update regularly..and you order and get an email that out of stock, discontinued etc.
    Timbuk3, MI
    Arrow
    RubberCtyRauder - alot of those part's websites do not update regularly..and you order and get an email that out of stock, discontinued etc.
    Am fully aware, and have 1st knowledge, of that. HOWEVER ...
    parts.ford.com is the official FoMoCo parts web site -AND-
    just checked tascafordparts.com and got the same results (parts listed, and shown).
    That and as mentioned ... "can substantiate that at least the LH front fender trim was available as of Sep'2017 - had need to buy one.".
    So if you're into OEM, NOS wouldn't hurt to check-with your local, friendly FoMoCo dealership parts counter for availability either thru existing stock or the FoMoCo parts network.
    Shoot Fire ... -ALL- (including 5W7Z-5425557-APTM) are even currently on ebaY® ... so much for being -obsolete-
    I think I have a full set minus the drivers fender one, was damaged
    The same moldings are found on OTHER than marauders too, might find some at the yard
    Oct 2003
    Beaufort, SC
    Get a piece of aluminum flashing and slide it down behind the molding to protect the door while you wet sand the bad places......then mask, prime and paint....EASY PEASY!!
    Have you even tried to remove those moldings yet......it's a NIGHTMARE!!
    May 2003
    Wichita Kansas
    Waiting to hear back from the body shop to see if they would be able to repaint them on the car. Last place I talked to when I first got the car would touch it with them still attached
    Sent from my SM-G955U using Tapatalk
    2004 SB
    4.10's and a tune
    More to come
    i was not aware that the door moldings were still available, i was going by older info that mentioned can't find them, get them...can get door moldings, but a headlight? or cross over tube?. i need nether, just as comment
    Timbuk3, MI
    Post
    Turbov6Bryan ... The same moldings are found on OTHER than marauders too, might find some at the yard
    1998+ Crown Victoria - P72 (commerical - standard wheelbase), P73 (civilian - base) and P74 (civilian - LX) models.
    Hiram, Georgia
    I may have a set.
    Let me do some looking.
    Blog Entries
    2
    Bought from Go-Parts in August
    998 - 2008 Ford Crown Victoria Rear Door Molding Right (Passenger)
    Item #: DM0001-0899068-0633249
    $57.95 USD 1 $
    Feb 2017
    New Orleans, LA
    x2, I damaged mine trying to 'fix' them up and said to hell with it and removed them all together. I much prefer the cleaner look of them being gone.
    May 2016
    T-Town
    Been there, done that.
    I think it looks better without the moldings. Well except for the round black decal covering a factory hole in the door...and what is that hole for?
  1. Wanted To Buy Side mouldings for front doors
    By stukibuilt in forum Marauder Parts/Misc. Wanted
    Last Post: 01-08-2014, 07:31 AM
  2. Body Side Mouldings Removed?NWS!
    By Bradley G in forum Community Discussion
    Last Post: 02-07-2012, 05:07 PM
  3. No Body Side Molding?
    By Marauderoz in forum Community Discussion
    Last Post: 08-14-2007, 07:07 AM
  4. Body side moulding peeling off!!!
    By adrian36 in forum Community Discussion
    Last Post: 01-03-2004, 08:10 AM
  5. body side mldg decal
    By MassMarauder in forum Community Discussion
    Last Post: 03-22-2003, 08:27 PM
