Results 1 to 5 of 5
Thread: Alternator Issue?
    Hello out there! I am having a bit of a small problem! I noticed last night while driving home from the All Ford Car Show that my lights would dim as I stepped on the gas and my voltage gauge would dip between 11-14. This leads me to believe that I might have a alternator problem. I have a 2003 300 A MM with a Trilogy Supercharger. I never had this problem before. Does anybody have any idea what the problem might be? Please help!!!!
    Aug 2004
    Maryland
    I do not know if this is a duplicate thread or not....
    Here is an alternator wire issue I had awhile ago. Search the Archives under Trilogy Motorsports.
    http://www.mercurymarauder.net/forum...ght=alternator
    11.98 @ 115 mph
    Jun 2002
    Soldering the splice connection is one solution. Make sure you use rosin not acid core solder.
    These days you can get solder with a good silver content as well.
    This is another excellent solution:
    Originally Posted by Tallboy
    Carfixer and I use Gardner-Bender brass butt-splice kits with brass set-screws, then the whole thing is heat-shrinked using adhesive lined tubing. Then, the harness is wrapped in a protective wire loom. Our customers need never to worry about this happening to them.
    It costs us a bit more to do it this way, but we feel it is worth it.
    Member Number 32
    Cape Cod
    Quote Originally Posted by DEFYANT View Post
    Yes, a duplicate copied from Claude and Paula's anniversary thread.
    MOK
    I don't brake for curves!
    Aug 2004
    Maryland
    Quote Originally Posted by MM03MOK View Post
    ..... thought I read this question somewhere.
    11.98 @ 115 mph
