MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Interior Electrical/Electronics
Interior Electrical/Electronics This is the place for questions/discussions of head units, speakers, navigation systems, alarm systems, heated seats, rear window defoggers, door locks, air bags, etc.
Reply
Thread Tools Display Modes
  #1
Old 12-06-2017, 03:12 PM
04MRADR's Avatar
04MRADR 04MRADR is offline
Member
Trader: (0)
Problem EATC Heat Coming Thru Vents
I have a 2004 Marauder and today I noticed my heat comes thru the vents when I choose either the floor, defrost, or floor and defrost buttons instead of coming through the floor or dash like it should. A few years ago I had a problem where my air conditioning came out of the floor and dash and nothing came out of the vents. I recall someone suggested I replace the washers in the EATC and sure enough that fixed the problem. I was wondering could this be the same thing again since I read elsewhere in another forum that the washers tend to dry out over time and not seal properly. Also noticed when I turn on or off the engine it sounds like a door opening or trying to open or close under the dash on the passenger side. Don't know if that has anything to do with this problem. Any suggestions on what the problem may be and if the washers I think last time a club member said you get them from a supplier in New Jersey. If someone could provide me with where I get the washers that would be most appreciated. Thanks ever so much. Have 219 K on the Marauder and still drive it and love it. Thanks for your help in advance.
__________________
2235 of 3214 built for 2004
766 of 1237 in Black
One of 156 built with Light Flint
Interior & Black Exterior
251 built of 509 with Moonroof
Born on April 1, 2004
Adopted on July 31, 2004
Magnaflow Mufflers
K & N Air Filter
CarMotorsports Under Hood God's Logo Pad
CarMotorsports Custom Floor Mats
  #2
Old 12-06-2017, 04:47 PM
Ambitious1's Avatar
Ambitious1 Ambitious1 is offline
Senior Member
Trader: (9)
You may want to reach out the FastBlackMerc, he is an expert in all thing involving the HVAC system.
  #3
Old 12-06-2017, 06:01 PM
NorthShoreChiMM's Avatar
NorthShoreChiMM NorthShoreChiMM is offline
Mike
Trader: (0)
FBM has an excellent repair thread with all diagnostic and repair steps. Its a sticky I believe
  #4
Old 12-06-2017, 06:10 PM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
Washers? If you meant the o-rings, as long as you used silicone ones they should not need replacement again.
The "door closing" sound on start-up or shut-down is normal.
Having air coming from the vents all the time means either the vent door actuator is bad or the vent door itself is disconnected or broken...not an uncommon issue.
__________________
  #5
Old 12-07-2017, 09:05 AM
Svashtar's Avatar
Svashtar Svashtar is offline
Trying to get it right...
Trader: (0)
This happened to me two years ago, after some auto body hacks in town beat on the car for a week fixing the right front quarter panel. I was able to fix it by resetting the EATC with the self test. The system ran through its cycle, there was a lot of thumping under the dash which I took to be the blend door opening and closing, then everything started blowing normally.
Try this first anyway:
“Key on, engine running: Press OFF and FLOOR simultaneously, then press AUTOMATIC within 2 seconds. The EATC will have to run some tests and do some thinking. It may take up to 30 seconds. Soon it may display some codes. Write these down. To exit self test press DEF.”
Look for error code 024 which is a fault in blend door calibration during the test, or code 025 which is an intermittent fault in blend door calibration. There are a bunch of others from 030 up to 125, but I don’t have all their descriptions.
Hopefully this will reset it for you like it did mine, but if not at least you gave it a shot and might get more info.
__________________
  #6
Old 12-07-2017, 09:40 AM
fastblackmerc's Avatar
fastblackmerc fastblackmerc is online now
Trader: (75)
Look for error code 024 which is a fault in blend foot calibration during the test, or code 025 which is an intermittent fault in blend door calibration. There are a bunch of others from 030 up to 125, but I don’t have all their descriptions.
Here is the exact procedure:
Electronic Automatic Temperature Control Module Self-Test Procedure
Interior of the vehicle must be between 40 - 90 degrees while running the test. If not you may get false in-car temperature sensor errors.
•The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A NGS tester must be used to retrieve these concerns.
• The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
• The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
• To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
• If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
• If a condition exists but no DTCs appear during the self-test, refer to the Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
• To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
• To exit the self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
• Always exit the self-test before powering the system down (system turned OFF).
• Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
__________________
  #7
Old 12-07-2017, 12:11 PM
Turbov6Bryan's Avatar
I miss whitey here
Trader: (5)
^^^ that should be a sticky
Do we have a section here, most common issues and how to test and repair?
That would be awesome
__________________
04 DTR
03 Black 300A
03 Black 300A
04 Supercharged SILVER BIRCH
04 SILVER BIRCH NA
  #8
Old 12-07-2017, 12:14 PM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (40)
I just had the identical problem you are having OP. The diverter door itself had self destructed and was just laying there. It required the complete removal of the dashboard, and a very difficult home repair. If I had to do it again, I would have bought a new HVAC box. Good luck
  #9
Old 12-07-2017, 12:30 PM
Zack's Avatar
Turbo Marauder
Trader: (40)
The diverter door hinge is made of plastic, just like you'd find on a beer cooler.
After so many cycles, they fail. Absolutely stupid design.
  #10
Old 12-07-2017, 01:10 PM
Trader: (75)
It is!
Interior Electrical/Electronic forum
__________________
  #11
Old 12-07-2017, 01:21 PM
Trader: (75)
Had the broken blend door on my '98 Ranger. Bought a kit to replace it that required you cut the bottom of the HVAC case. I replaced the blend door actuator while I was in there.
__________________
  #12
Old 12-07-2017, 01:23 PM
Zack's Avatar
Turbo Marauder
Trader: (40)
Quote:
But in my case, it was not the blend door. It was the door that decided vent or floor.
  #13
Old 02-03-2018, 03:00 PM
b1vjgb3's Avatar
b1vjgb3 b1vjgb3 is offline
Ford Man since 1956
Trader: (0)
Does anybody know where the heater control valve is located ?
  #14
Old 02-03-2018, 04:32 PM
b1vjgb3's Avatar
Ford Man since 1956
Trader: (0)
The problem with my silver car is that the heat doesn't come on right away. I can get heat by turning the EATC up to 90 and revving the engine to about 3000 rpm and then the heat comes on.
I suspect the problem to be either the heater control valve (don't know where it is but I have a new one) or the heater core is clogged.
The car has just over 198,000 miles on it.
  #15
Old 02-03-2018, 05:58 PM
Trader: (75)
Ford and other manufactures eliminated the hot water valve and replaced it with the blend door. Apparently the continuous flow of water thru the heater core is better than no flow.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Heat coming from the top and bottom of dashboard with no air or heat on. Mrauder83 Shop Talk 12 10-18-2016 07:17 AM
EATC / blower issue - nothing out of the vents efi4eye Shop Talk 1 11-28-2015 05:05 PM
Heat problem Blower not coming on and etc blackcobra95 Shop Talk 3 11-15-2011 01:21 PM
EATC and BCM are fine yet air only blows out vents DeadVic Shop Talk 6 12-12-2010 11:56 AM
EATC Stuck on Dash Vents brianzpatton Shop Talk 7 10-11-2010 01:06 AM
Powered by: vBulletin
