MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Exhaust
Exhaust Post your discussions about exhausts, mufflers, tips, headers and manifolds here!
Reply
Thread Tools Display Modes
  #1
Old 12-06-2017, 11:47 PM
lifespeed lifespeed is offline
Senior Member
Trader: (1)
Emissions-legal catalytic converter upgrade
Not sure how many will find this interesting, but there is plenty of evidence restriction after the exhaust manifold (pipes and cats) are a source of horsepower loss. Short of installing long-tube headers, the best you can do is open up the exhaust including the cats. We have 2" from the factory, although it does choke down to 1-3/4" after the rear cats. Even stock engines benefit from less restriction here. Although I can't find the article where somebody did a before/after dyno with exactly this experiment, it was worth about 20 HP on a bolt-on only engine. Modified would be worth more.
As more states adopt the restrictive CARB rules, knowing how to live within the rules without re-configuring your car every few years could be useful information.
If you look at the CARB catalytic converter database you find a list of aftermarket converters that have been officially blessed by application. There are bolt-ons assembled with pipes, but what we want are larger cats with an EO number for our cars. Turns out AP emissions makes #761015 which is approved under CARB EO D-754-1. This is a 2" cat, and the same part number is approved for front and rear locations. However, they make the same part in 2-1/4" and 2-1/2" under the same EO number! these are part numbers 761016 and 761017 respectively. I need to confirm, but I believe the numbers stamped on these that are checked at inspection (if your cats have been replaced) are the EO numbers, not the manufacturer part number - the same for all sizes.
So buy some stainless mandrel U-bends from Burns stainless (press bends are verboten for horsepower), make sure you hire a skilled exhaust guy, and go to town!
__________________
Lifespeed
  #2
Old 12-07-2017, 06:06 AM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
Good info. Now trying to find a skilled exhaust guy. Oh wait, thatís me..
__________________
  #3
Old 12-07-2017, 09:29 AM
Lowndex's Avatar
Lowndex Lowndex is offline
Middle Age Crisis Member
Trader: (3)
justbob,
Are you relocating to northern CA?
  #4
Old 12-07-2017, 09:44 AM
88LTDCV351's Avatar
88LTDCV351 88LTDCV351 is offline
Senior Member
Trader: (2)
These aren't high flow, right? Just allow for bigger pipes?
__________________
1988 LTD Crown Victoria S
  #5
Old 12-07-2017, 10:18 AM
Senior Member
Trader: (1)
Quote:
I didn't see flow rates published. CARB actually dictates mfg's can't advertise improved flow. Might have to call AP Emissions. That said, the before/after Dyno on the Marauder cat/pipe upgrade was done with stock Mustang cats, not "high flow" aftermarket. I think they may have been 2-1/4". It could be the pipe size of the cat is important. The cross-section of the catalyst is far larger than the pipe.
__________________
Lifespeed
  #6
Old 12-07-2017, 11:37 AM
Lowndex's Avatar
Trader: (3)
BRG Racing highly recommends:
http://www.spdexhaust.com/
Ask for Chris!
Supposedly (no personal reference), high rated auto exhaust shops:
San Jose:
https://www.yelp.com/search?find_des...&sortby=rating
Hayward:
Sacramento:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Catalytic converter badass mm Exhaust 16 07-14-2017 07:11 PM
Catalytic Converter(s)? Hauser717 Shop Talk 28 07-14-2016 06:35 PM
Catalytic converter issues elDUQUE Exhaust 1 12-01-2014 09:02 PM
Catalytic Converter Pat Shop Talk 16 02-04-2010 04:14 PM
Catalytic Converter Directedby Community Discussion 2 12-25-2002 07:11 PM
Powered by: vBulletin
