MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 05-14-2019, 04:20 PM
Talal DTR MM's Avatar
Talal DTR MM Talal DTR MM is offline
Senior Member
Trader: (0)
Correct OEM part # for Engine pistons & piston ring
Hi Guys,,
Time has come now to get my beauty 2004 dtr marauder back to life. Dou to personal commitment, I wasn't able to repair the misfired engine & decided to keep her in my garage since last sep'17.
Anyway, mechanic requested me new engine pistons with rings in addition to other parts.
I got piston rings part #Piston Rings - Ford (6L3Z-6148-A) but did not fit on stock piston while dealer is telling it should fit mercury marauder as well as crown vic & grand marquis (as per shown to them in system)!!
If anyone has experience with the correct oem part no. for piston & ring to enable me ordering it online and avoid getting marquis/crown vic parts by mistake
Thanks in advance.
  #2
Old 05-15-2019, 08:34 AM
Mr. Man's Avatar
Mr. Man Mr. Man is offline
GAME OVER, YOU LOSE!
Trader: (2)
I would think you would need Aviator or Mach1 pistons. Ford dealer should know the MM is a DOHC engine not a SOHC.
Check with Marty at MO'S (vendor)he can probably get you hooked up with the best and correct products.
  #3
Old 05-15-2019, 08:59 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
Poster is in Saudi Arabia..big difference in Ford dealership knowledge here and their
__________________
  #4
Old 05-15-2019, 12:56 PM
Senior Member
Trader: (0)
Thanks Mr. Man & RubberCtyRauder for your response.
Actually, I already did compare the parts for marauder along with lincoln aviator & mustang mach 1 & got the correct part #
1- engine piston # 2C5Z-6108-AB
2- piston ring # 2F3Z-6148-BA
I'm almost to place my order with one of ford parts dealers in OH. (Beechmont) but the guy telling the available piston only grade 1? Is this for standard piston size ? as he sent lengthy manual without mentioning if it's for standards or oversized piston ?
Waiting your response pls.
  #5
Old 05-19-2019, 11:47 AM
Senior Member
Trader: (0)
I took a look at MMR website & found pistons & connecting rods with prices better than other websites but I don't know which is suitable for my rebuild !!
I want to keep the engine on high compression same as stock with a future plan to boost it with max. 550+rwhp.
Any suggestion on aftermarket pistons & connecting rods with good prices!!
  #6
Old 05-19-2019, 12:21 PM
Weißbirke Plünderer
Trader: (11)
You don't want stock pistons and rings for boost anyway.
__________________
  #7
Old 05-19-2019, 12:41 PM
Senior Member
Trader: (0)
Quote:
As complete head valves need to be replaced & I already have mmr ss valves set which I believe the high mileage rings(180,xxx ) will not withstand. So, I found it a good opportunity to replace high mileage pistons & rods with aftermarker ones.
  #8
Old 05-19-2019, 12:45 PM
Weißbirke Plünderer
Trader: (11)
You want forged pistons, rods, crank for 550 hp
__________________
  #9
Old 05-19-2019, 01:03 PM
Senior Member
Trader: (0)
Yup. But stock 6 bolts crank can handle upto 600hp, am I right?
  #10
Old 05-19-2019, 01:17 PM
Themarauderguy's Avatar
Themarauderguy Themarauderguy is online now
Senior Member
Trader: (0)
I heard the cast crank was good to 600 horsepower at the crank. which should be around 500 at the wheels. if you want 600 at the wheels you're going to need a forged crank. unless you just want to gamble. You could always be the guinea pig. and let us know how much horsepower it takes to break a stock crank. Lol
  #11
Old 05-19-2019, 01:34 PM
Weißbirke Plünderer
Trader: (11)
I've heard cast crank good for 600+ rwhp...so 750 crank..everything is s gamble in reality. Most people go to 8 bolt cranks when building motors
__________________
  #12
Old 05-19-2019, 02:26 PM
Senior Member
Trader: (0)
Yes very true. I didn't know that were rated for that much that's really not too bad. totally agree on the gamble side of it though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Correct COP part # from Motorcraft? HotRaud90 Shop Talk 7 09-26-2015 05:09 PM
Are these part numbers correct still? (J-mod) ctrlraven Transmissions 15 03-17-2011 08:11 AM
Piston Oil squirters - New 5.0L Engine & our's Loco1234 Shop Talk 10 04-01-2010 02:49 PM
Verify Correct Part Number fastblackmerc Community Discussion 13 02-17-2006 05:48 AM
Powered by: vBulletin
